Is there a way in Python 3.x to programmatically select a layout element, such as a scale bar? Thanks much, cob
they give an example of moving a scalebar in this tutorial
Create a map book with Python—ArcGIS Pro | ArcGIS Desktop
Thanks Dan, but it is actually never selected in that example, just repositioned. I can set the map frame as well, but there must be a programmatic way to select the element, so that when I open the properties page with a task step it pertains to the selected element?
Charles, you will need to sniff around in the arcpy section for other examples of **element things.
For example
MapsurroundElement—ArcPy | ArcGIS Desktop
but it requires you know the element name
Yes I know the name - I can set the map frame and do all sorts of things to the elements, but can't figure out how to select one. I also don't see how to add items to the Legend_Element but I think this is another bug issue. Thanks, cob
