Can we create API locally server not on the ESRI server.
ie. i have https://tiles.arcgis.com/tiles/Ezk9fcjSUkeadg6u/arcgis/rest/services/OPCNM/VectorTileServer
I want to create this api
https://localhost:5272/Tiles_VectorTileServer
Here are a couple more samples that do not use ArcGIS Enterprise as the primary data source:
KMLLayer | ArcGIS API for JavaScript 4.14
OpenStreetMapLayer | ArcGIS API for JavaScript 4.14
WebTileLayer | ArcGIS API for JavaScript 4.14
WMSLayer | ArcGIS API for JavaScript 4.14
WMTSLayer | ArcGIS API for JavaScript 4.14
Select WMTSLayer sublayer | ArcGIS API for JavaScript 4.14
GeoJSONLayer | ArcGIS API for JavaScript 4.14
GeoRSSLayer | ArcGIS API for JavaScript 4.14
Intro to CSVLayer | ArcGIS API for JavaScript 4.14
CSVLayer - Project points on the fly | ArcGIS API for JavaScript 4.14
Custom TileLayer | ArcGIS API for JavaScript 4.14
Custom DynamicLayer | ArcGIS API for JavaScript 4.14
Custom LERC Layer | ArcGIS API for JavaScript 4.14
CIMSymbol | ArcGIS API for JavaScript 4.14
Satellites in 3D view | ArcGIS API for JavaScript 4.14
Thank you so much for reply.
Firstly can you provide me sample code to convert GeoJson to Feature layer.
Second, I have mostly NDVI images they are tiff files. That's why i was using tiles to display my Tiff files.
If you have any other way we can display tiff image. Without ArcGis Server.
Thirdly,I was thinking about postGresql to save these layer.
When it comes to feature layers, you're not bound to ArcGIS Server. For example, check-out ArcGIS API for JavaScript Sandbox
This sample uses GeoJSONLayer, but you can also create a FeatureLayer from the graphics returned by a geojson call... it's just a little more work. Let me know if GeoJSONLayer isn't something you can use and I'll supply a sample for converting GeoJSON into a FeatureLayer.
You can also create layers using CSVs - ArcGIS API for JavaScript Sandbox
For tiles, can you use ArcGIS Online? Also, have a look at this - https://community.esri.com/thread/184269-is-it-possible-to-render-mapbox-vector-tiles-pbf-from-a-custom-tile-server
I am looking for Tiles , feature layer, etc outside ArcGis server.
Yes. Can we create tiles service outside ArcGis Server?
Are you asking if you can create a tile service outside of ArcGIS Server? You mentioned the API, which can be hosted locally, but it doesn't sound like this is what you're looking to accomplish.
