Hey all,
When I tried to assign street with Esri rule files. All my streets show "unknown textures" I have no idea why. Anybody knows?
try to copy the "assets" folder from the original project which has the rule in it and paste it in your project in the same name of the folder "assets"
Thank you for telling me to turn off the graph network. After that they look like this, how am I going to remove those black lines?
But without Network it only shows like this
you can also turn the street network layer off using the 2nd of the 4 layer toggles at top of viewport
Micah is correct, the points are a result of the segment network layer being turned on. You only want to show polygon models when showing street segments. Those points will appear in screen shots as well if you take them unless the segment lines are toggled off in the display.
Also judging by the number of breakpoints, your network might benefit from a simplify graph run.
Is that screen shot from the CityEngine viewport? If so, it looks like you have the graph network turned on. Try turning the graph network off from the toolbar at the top and see if that removes the black lines.
Thanks Chris that's helpful. However I still get this dark spot and dark lines in my streets. I don't see these on the tutorial video. Are they normal?
If you open the rule, and search for file paths or images, such as ".jpg", you can find the path to the textures, and match those to where your texture files are. OR, you might realize you don't have the texture files.
