Andrea, Sure, just add this to the bottom of the init function:wTemplate.selectedTitlebarButtonIndex = 1;
Andrea, Not until you start using the source code then you can do this <viewer:BaseWidget xmlns:esri="http://www.esri.com/2008/ags" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:Search="widgets.Search.*" xmlns:viewer="com.esri.viewer.*" x="600" y="300" widgetConfigLoaded="init()" currentState="textInput">
<expression>AssessorNum_diss LIKE '%[value]%'</expression>
<expression>Upper(AssessorNum_diss) LIKE Upper('%[value]%')</expression>
<expression>AssessorNum_diss = '%[value]%'</expression>
<expression>AssessorNum_diss = '*[value]*'</expression>
<expression>AssessorNum_diss = '[value]'</expression>
<expression>AssessorNum_diss = [value]</expression>
<?xml version="1.0" ?> <configuration> <layers> <layer> <name>Parcels</name> <url>http://ptovar-pc/ArcGISServer/rest/services/TEST/Parcels/FeatureServer/0</url> <expression>AssessorNum_diss = '[value]'</expression> <textsearchlabel>Search by Parcel ID [ Example: L18100149000 ]:</textsearchlabel> <titlefield>AssessorNum_diss</titlefield> <linkfield></linkfield> <fields all = "true"> <field name="AssessorNum_diss"/> </fields> </layer> </layers> <zoomscale>5000</zoomscale> <info>widgets/InfoTemplates/InfoPopupWidget.swf</info> </configuration>
