Im Problem findtask need help:do not show results it is emptyDataMAp: http://www.mediafire.com/download.php?qyg3b97pzpngcqbCode<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Find</title> <link rel="stylesheet" type="text/css" href="http://localhost/arcgis_js_api/library/1.6/arcgis/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://localhost/arcgis_js_api/library/1.6/arcgis/"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.find"); var find, params; function init() { find = new esri.tasks.FindTask("http://localhost/ArcGIS/rest/services/gisDuLich/DuLich/MapServer"); params = new esri.tasks.FindParameters(); params.contains=true; params.returnGeometry=true; params.layerIds = [0,1,2,3,4,5,6,7,8]; params.searchFields = ['maDoiTuong','danhTuChung','diaDanh','diaChi','doiTuong','maNhanDang','ngayThuNhan','ngayCapNhat','maDoiTuong','maDonViHanhChinh','danhTuChung','diaDanh','dienTich','nhandang','ten']; } function doFind() { params.searchText = dojo.byId("searchText1").value; find.execute(params, showResults); } function showResults(results) { alert("Don't shows results "+results); var result, attribs; var s = ["<table border=\"1\"><thead><tr style=\"background-color:#ccc;\"><td>OBJECTID</td><td>Dia Danh</td></tr></thead><tbody id=\"states\">"]; dojo.forEach(results,function(result){ attribs = result.feature.attributes; alert(result.feature.attributes); for (j in result.feature.attributes) { alert(j); if (j.toUpperCase() != "OBJECTID" && j.toUpperCase() != "SHAPE") if (result.feature.attributes.toUpperCase() != "NULL") s.push("<tr><td>" + j + "</td><td>" + result.feature.attributes+ "</td></tr>"); } }); s.push("</tbody></table>"); dojo.byId("tbl").innerHTML = s.join(""); } dojo.addOnLoad(init); </script> </head> <body class="claro"> Dia Danh: <input type="text" id="searchText1" size="40" value="Trường" /> <input type="button" value="Find" onclick="doFind()" /> <div id="tbl"></div> </body></html>
HELP ME PLEASE!
What have you tried? What errors are you seeing? Do you see the request going to the layer in your map service?Consider using 3.0 as it is the latest version of the API.
