Beyond frustrated trying to use collector for offline editing. Publishing feature service direct from the DEFAULT sde, and can view and edit in collector, but trying to add an offline area it tries and fails every time with the message "No offline areas". Server manager log says "Error executing tool. CreateFeatureServiceReplica Job ID: jc2c02e9384ac4742a6e0b3ba139266c3 : ErrorMsg@SyncGPService:{"code":500,"description":"Failed to create replica."} Failed to execute (Create Feature Service Replica)."
I was finally able to download an offline map area when I copied the feature classes I need into a standard gdb on the same server and published my feature service from that, but even then I get unknown sync error. Server log says "Error executing tool. SyncFeatureServiceReplica Job ID: j39af3c32d7204e2cbe5147b35c6ab965 : ErrorMsg@SyncGPService:{"code":400,"description":"DBMS table not found"} Failed to execute (Sync Feature Service Replica)."
We are using vpn to connect to our inside network on the mobile device.
We have made multiple calls to support over the last few weeks, and every time they insist we need some kind of software upgrade or patch. None of which has ever made the slightest difference except eat up our time.
What we have done:
Upgraded to ArcGIS 10.5.1
Installed and federated Portal
Applied various patches and updates
Not sure what other information will help.
