import arcpy from arcpy import env env.workspace = "C:/drainagescripting/inputdata/drainagedatasp.gdb" # THIS WORKS - prints 'true' print arcpy.Exists("C:/drainagescripting/inputdata/drainagedatasp.gdb") # THESE return '[ ]' fclist = arcpy.ListFeatureClasses() print fclist
I'm not sure why it wouldn't work for you, assuming there is actually some feature classes in the .gdb.
I modified you code slightly
<SPAN class="keyword token">import</SPAN> arcpy <SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> theWorkspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:/__temp/test.gdb"</SPAN> <SPAN class="comment token"># THIS WORKS - prints 'true' </SPAN> <SPAN class="keyword token">print</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>theWorkspace<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># THESE return '[ ]' </SPAN> fclist <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN>fclist<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
and my results were..
True[u'newpts', u'newPtsMySR', u'test', u'testout2', u'StudyZones', u'bl00_point']
so, take a look at your .gdb to see what is in there.
If the feature classes reside in feature dataset then you need to include the feature dataset name in the path.
