There is no labeling ability.Thanks,Mike
The ArcGIS.com website doesn't support adding text as graphics. However, you can use another application, ArcGIS Explorer Online to do so. http://www.arcgis.com/explorer. Sign in and you should be able to open any web map you created in ArcGIS.com.Mike
Check out this resourse on adding labels to ArcGIS online. I've only tried it for a few features and it seems to work okay as long as you get them placed properly in arcmap.http://blogs.esri.com/esri/arcgis/2011/11/21/adding-labels-to-arcgis-online-web-maps-part-1/
Here is a somewhat complex process that allows you to add labels without having to create a tile map service. If the search function on the forums was worth a damn, I might have found this by myself. But ESRI tech suport (Jegan) found it in a few seconds.Adding labels to ArcGIS Online web maps: Part 1 Adding labels to ArcGIS Online web maps: Part 2
