You can get at this with Python:
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> fc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'points'</SPAN> <SPAN class="comment token"># feature class/layer</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> field <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Id'</SPAN> <SPAN class="comment token"># field to inspect</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> start <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="comment token"># first value</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> stop <SPAN class="operator token">=</SPAN> <SPAN class="number token">25</SPAN> <SPAN class="comment token"># last value</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> step <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="comment token"># increment value</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> present_values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN>field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># load present values to list</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> missing_values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>i <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN>start<SPAN class="punctuation token">,</SPAN>stop<SPAN class="punctuation token">,</SPAN>step<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> i <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> present_values<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># compare present values to possible values</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN> missing_values <SPAN class="comment token"># print list, or do some thing with values</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">21</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">22</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">23</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">24</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Skipped meaning they are out of order from the others?
6
23
7
8
9
10 ?
Can you sort ascending or descending to find them? Look for duplicates?
