I am not normally a programmer myself, but I've used ESRI's model builder and exported models to python scripts that can be executed as part of a batch file. It's not too hard to do, but I don't see a standard toolbox to use and may need to be handled by python.Basically I need to build a model to trigger ESRI's "Calculate Geometry" function, returning results in decimal degrees or DMS. I don't see any toolboxes to serve that purpose. After searching online, all I can find are python scripts using the CalculateValue toolbox to return the X-Y values. But they're returned in feet and I need to have decimal degrees.I found a script that looked like what I needed, but it required the Defense Mapping extension in order to use it, which I don't have. Any easy answers?
import arcpy from arcpy import env env.workspace = r"C:\temp\python\test.gdb" fc = "Mains" rows = arcpy.UpdateCursor(fc, "", "Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj") for row in rows: geom = row.shape row.Area_DD = geom.area rows.updateRow(row) del row, rows
