theFeatureList = [ [59.9359664290001, 58.2873293230001], [59.9354474180001, 58.292897049], [59.9359664290001, 58.2873293230001], [15.7361337040001, 69.5741156380001], [5.46961326000007, 74.605524862], [21.6743239320001, 90.0000000000001], [61.6145099540001, 90.0000000000001], [74.588779291, 78.7328713650001], [74.9956238680001, 62.052243682], [59.9359664290001, 58.2873293230001], [29.5877337620001, 75.2087581980001], [29.5902670670001, 75.2091884760001], [29.5877337620001, 75.2087581980001] ]
you want: this
Ha, now I see it. It's hard to read unformatted.So, it looks like you initially get an array of x,y values for the first part of the polygon with this:for pnt in inShape.getPart(polyIndex):Now you need to pull the the individual points from the array that is the first part of the first polygon record in your feature class. Think of multipart features.
I don't see where 'pnt' is defined, so it can't have an attribute 'X'.
import arcpy, os dist = r"N:\Projects\120802 CEMA Landscape Simulation Modelling for RMWB\05- Data\glink_seismic_Buffer_ClipExample.shp" origin = r"N:\Projects\120802 CEMA Landscape Simulation Modelling for RMWB\05- Data\section_for_clipping_disturbance_features.shp" sqrs = r"N:\Projects\120802 CEMA Landscape Simulation Modelling for RMWB\05- Data\sections_analysis.shp" outfolder = r"N:\Projects\120802 CEMA Landscape Simulation Modelling for RMWB\05- Data" outpoly = r"seismic_tile_example.shp" try: arcpy.Delete_management(outfolder + "/" + outpoly) except: pass arcpy.CreateFeatureclass_management(outfolder, outpoly, "POLYGON", "", "", "", dist) distdesc = arcpy.Describe(dist) distshapefieldname = distdesc.ShapeFieldName squaredesc = arcpy.Describe(sqrs) squareshapefieldname = squaredesc.ShapeFieldName originpoly = arcpy.SearchCursor(origin) squares = arcpy.SearchCursor(sqrs) inRows = arcpy.SearchCursor(dist) outRows = arcpy.InsertCursor(outfolder + "/" + outpoly) polyarray = arcpy.Array() origindesc = arcpy.Describe(origin) originshapefieldname = origindesc.ShapeFieldName orig = originpoly.next() originvalue = orig.getValue(originshapefieldname) origincentroid = originvalue.centroid for square in squares: squarevalue = square.getValue(squareshapefieldname) squarecentroid = squarevalue.centroid xoffset = squarecentroid.X - origincentroid.X yoffset = squarecentroid.Y - origincentroid.Y polyIndex = 0 for inRow in inRows: inShape = inRow.shape pntObj = arcpy.Point() arrayObj = arcpy.Array() for pnt in inShape.getPart(polyIndex): pntObj.ID = polyIndex pntObj.X = pnt.X + xoffset pntObj.Y = pnt.Y + yoffset arrayObj.add(pntObj) outShape = outRows.newRow() outShape.shape = arrayObj outRows.insertRow(outShape) polyIndex += 1
