Is there a way to see the ArcSoc usage, max, avg, P50 and so on, over time, without the ArcSoc optimizer?
I want to decide by myself which service to increase.
Ofra
What about running the ArcSOC Optimizer in list mode? This will generate the report but it does not change the min and max instance settings, so you get to review the report and decide what changes to make.
If you are ok with doing an average of your ArcSOCs you can try using the process counter that comes out of the box with ArcGIS Monitor.
Counter status view glossary—ArcGIS Monitor | Documentation for ArcGIS Enterprise
Just to make the question more clear.
It is easy to see how many instances is open but when you have many of them, each one with a different maximum it is to easy to see witch one does not have max instances big enough.
