Hello,I just got here from google having searched for "arcgis geometric network load flags from points". Anyway a slightly different search changing the word "points" to "file" came up with this tool:http://edndoc.esri.com/arcobjects/8.3/Samples/Network/Utility%20Network%20Analysis/Edge%20Flags%20From%20Points/EDGEFLAGSFROMPTS.htmwhich although it is apparently for Arcobjects 8.3, has loaded fine into Arcmap 10, and seems to do exactly what you are looking for.As for me I've realised that i'm better off using Network Analyst for what i'm trying to accomplish (find routes from lots of upstream points in turn to a single downstream point). This may work better for you as well if you're tracing from all source points to the river mouth. Use a Closest Facility analysis, add the mouth / downstream point as a Facility, add all your source points as Incidents, and hit solve.Harry
HiI am working on the same thing, have you got an answer, or figured it out...Thanks-A
