I published a feature class with attachments to ArcGIS online and added attachments (photographs--jpgs about 800 kb each) to a number of feature points. When I add the data to ArcGIS desktop standard (10.1) by dragging the published service into my map from Catalog, and select one of the points, the attachments are listed, but when I try to open them with Attachment Manager, nothing is visible. I also tried opening the online map using ArcGIS desktop from ArcGIS online (selected "Open in ArcGIS 10 for desktop"). Again I can select the same point, but the attachment cannot be viewed. The attachments can be viewed using map viewer in ArcGIS online. Does anyone have any suggestions about what the problem areas might be?
James, thanks for the tips. HTML popup works just fine. This would work as a possible workaround, but I am still wondering why the same attachments cannot be seen via Attachment Manager in ArcMap.
I think I have tried everything you suggested. When I use the pop-up tool, I can see the attributes, but the jpg comes up as a window with the name of the jpg file with a small box with an X through it. I went into the HTML popup tab of the properties and checked the download attachment data checkbox (it was unchecked), but nothing changed. Any suggestions?
Thanks for the help. I have attached a jpeg of the HTML popup tool tab from properties on the feature service layer added to my desktop. I don't see any reference to "Show feature attachments as links". Maybe I am looking in the wrong place? Can you help.
