I am building an arcgis map based application using the ArcGis javascript web API. I would like to know how to zoom out / in the map to view a full set of points.
Thank you for your help.
Regards,
Mohammed
Can you supply some more detail? Is this using the 3.x or 4.x version of the API? Is your point dataset a feature layer?
Here are two reference on getting the full extent from a feature layer, for example:
Layer | API Reference | ArcGIS API for JavaScript 4.6
FeatureLayer | API Reference | ArcGIS API for JavaScript 3.23
I am using the version 4, i am pushing my points directly into graphic layer.
Hope this help you.
The GraphicsLayer also has a fullExtent property
GraphicsLayer | API Reference | ArcGIS API for JavaScript 4.6
So, in your opinion, if i put this line of code : view.extent = view.graphics.fullExtent; , that will work ?
