Is there a way to change the text font size and specify the number of decimals shown on the pie chart in Operations Dashboard please?
Thank you,
Emily
Hi Emily,
> Is there a way to change the text font size and specify the number of decimals shown on the pie chart in Operations Dashboard ...
Yes, these options can be set in the Pie Chart configuration panel > Chart > Chart Options
There is a font size parameter and under Formatting > Value.
Hope this helps,
Derek,
Thank you very much for your reply.
I don't see your option, is it because I'm using the Portal version?
That might be the case. What release of ArcGIS Enterprise (Portal for ArcGIS component) are you using? It could be you're using an older/earlier Operations Dashboard release.
You’re right Derek. I’m using ArcGIS Enterprise 10.6.1. Upgrading ArcGIS Enterprise would require the entire setup of Portal, web adaptors, Data Store, federating, SQL and Windows authentication again, right? It’s not a simple upgrade as ArcGIS desktop or ArcGIS Pro, correct?
Thanks again,
