When you go to the Map Details page do you see any Application Properties towards the bottom of the page. The properties should have Routing, Measure, Basemaps enabled by default.Russ
The Android version will display the gps error in the notification tray, You should see a white or red icon when collecting, red means currently the error is higher than your threshold, white is within your threshold. If you swipe down the drawer you'll be able to see the actual error number. Regarding attachments can you provide more details. What device are you using, what version of android are you running and what app were you using to attach a photo (gallery, g+ photo etc.) or camera app. We have seen a bug with the stock gallery app and the auto-backup folder on some devices however it looks like itst a bug with the gallery and not the collector.
I am using a Samsung Galaxy 3S. The android version is 4.1.2 and I am using Collector to attach the photo.
Can you reproduce the attachment crash on any map with a hosted service that has attachments enabled?ThanksRuss
Is your S3 on Verizon? Can you download another camera app called "Camera MX" and try to use that instead of the stock camera app?ThanksRuss
it looks like its a memory issue with the camera app and not the collector on some samsung devices and that we�??re investigating if theres anything we can do in collector to work around it. We did notice that the Camera MX app was still working within the Collector app when the stock camera app was causing issues when we used it attached photos.CheersRuss
Hello Russ:The CameraMax app did work. The only issue is the length of time it took for the phone to update the map. A best practice would seem to be to not be too quick to walk "off-station" while waiting for the map to update with the attached photo. One new wrinkle: For some reason there is now a copy of the map I was updating in my ArcGIS Online account for organizations. I suppose it is possible I somehow created a copy, I am just not sure of the new web map copy. Both updated fine vai the collector app and photo MX. Thanks for the suggestion. Rob
How big is the resolution in your photos? I have noticed that if photo being save has a high resolution setting it can take a bit to upload. If I change the resolution to a lower setting, the attachment is saved quicker.
