var file = dom.byId("uploadFile").files[0]; //where "uploadFile" is the id of your html file input var reader = new FileReader(); var fileContent = reader.readAsText(file); alert(fileContent);
<input id="uploadFile" data-dojo-id="uploadFile" type="file"/> <input type="button" data-dojo-id="uploadButton" type="dijit/form/Button" value="Load..." onClick="loadFile()"/>
function loadFile() { require(["dojo/dom", "dojo/request/xhr"], function(dom, xhr){ xhr.post("<url to your server script>", { data: { filePath : dom.byId("uploadFile").value } }).then(<callbackfunction>); }
function exportData() { require(["dojo/json", "dojo/_base/array", "dojo/request/iframe"], function(JSON, array, iframe){ var exportData = []; array.forEach(map.graphics.graphics, function(g) { exportData.push(g); }); var jsonString = JSON.stringify(exportData); iframe.post("<url to your server script>", { data : { records : jsonString }, timeout : 10000 }); }); }
function exportGraphics(){ var graphicList = []; $.each(map.graphics.graphics, function(index, graphic){ var graphicStr = JSON.stringify(graphic.toJson()); graphicList.push(graphicStr); }); $.generateFile({ filename : 'graphics.txt', content : graphicList, script : 'download.php' }); }
Based on what I learned so far this can not be done by JavaScript alone.
function exportToWord() { //exports the addresses of the parcels in the graphics file to a text file //on the users desktop and then opens it with the Word label template. if (!dojo.isIE) { alert("Exporting to Word only works with Internet Explorer"); return false; } //note this will give them a warning about ActiveX object running var wshshell = new ActiveXObject("wscript.shell"); var strDesktop = wshshell.SpecialFolders("Desktop"); var fso = new ActiveXObject("Scripting.FileSystemObject"); var bolOwner = false; //text file for property locations fProps = fso.CreateTextFile(strDesktop + "\\plist.txt", true); fProps.WriteLine("NAME;ADDRESS;ZIP"); var graphic; for (var i = 0, il = map.graphics.graphics.length; i < il; i++) { graphic = map.graphics.graphics; if (graphic.attributes) { fProps.WriteLine(graphic.attributes["OWNER1"] + ";" + graphic.attributes["ADDRESS1"] + ";" + graphic.attributes["ZIPCODE"]); } } fProps.Close(); //now open the word label template which contains VBA to dump the olist.txt into a new doc var w = new ActiveXObject('Word.Application'); w.Visible = true; w.Documents.Open("C:\\TEMP\\Plabeltest.docm"); }
It will be a great point to start, though what I need is the ability to save the graphics to a external file that can be shared among users. would you share the code?:)
function addToMap(geometry) { //drawToolbar.deactivate(); a = dijit.byId("tslider").value; c = hexToRgb(graphicColour, a); fullcolour = new dojo.Color(c); // fillStyle = dijit.byId('fillSelect').attr('value'); var psize = dijit.byId("font.size").value; psize = psize.replace("pt", ""); switch (geometry.type) { case "point": var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, psize, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color(graphicColour)); if (drawtype == 'Text') { fullcolour = new dojo.Color([0, 0, 0, 255]); var font = new esri.symbol.Font(dijit.byId("font.size").value, esri.symbol.Font.STYLE_NORMAL, esri.symbol.Font.VARIANT_NORMAL, esri.symbol.Font.WEIGHT_NORMAL, "verdana"); var symbol = new esri.symbol.TextSymbol(dijit.byId("usertext").value, font, fullcolour).setAngle(0).setOffset(0, 0).setAlign(esri.symbol.TextSymbol.ALIGN_START).setDecoration(esri.symbol.TextSymbol.DECORATION_NONE).setRotated(false).setKerning(true); } break; case "polyline": var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, fullcolour, dijit.byId("line.size").value); break; case "polygon": var symbol = new esri.symbol.SimpleFillSymbol(dijit.byId('fillSelect').attr('value'), new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0]), dijit.byId("line.size").value), fullcolour); break; } console.debug(symbol) var graphic = new esri.Graphic(geometry, symbol); // store to local storage graphic added var now = new Date(); var n = now.getTime(); GraphicName = "storedGraphic" + n; window.localStorage.setItem(GraphicName, dojo.toJson(graphic.toJson())); graphic.setAttributes({ newID: GraphicName }); userGraphics.add(graphic); //enableID(); }
//graphics stored in local srtorage and display it. for (var i = 0; i < localStorage.length; i++) { var n = "SavedGraphic" + i; var key = localStorage.key(i); //we use local storage for other things, so only read in storedgraphics if (Left(key, 8) == 'storedGr') { saved = dojo.fromJson(localStorage.getItem(localStorage.key(i))); var graphic = new esri.Graphic(saved); graphic.setAttributes({ "ID": n, "LSNo": i }); userGraphics.add(graphic); } }
function createToolbarAndContextMenu(map) { map.enableSnapping({ snapKey: dojo.keys.copyKey }); // Create and setup editing tools editToolbar = new esri.toolbars.Edit(map); dojo.connect(editToolbar, "onDeactivate", function(tool, graphic, info) { //we need to remove the version in local storage as we will be saving a new version //if Graphics has newID it has been added this session //If not it has been loaded from localstorage //if from LS the attribute LSNo will equal the index no in localstorage if (graphic.attributes.newID) { localStorage.removeItem(graphic.attributes.newID); } else { localStorage.removeItem(localStorage.key(graphic.attributes.LSNo)); } //save a new version with name time stamped so it can be referred to in future edits/deletes this session var now = new Date(); var n = now.getTime(); GraphicName = "storedGraphic" + n; window.localStorage.setItem(GraphicName, dojo.toJson(graphic.toJson())); }); dojo.connect(map, "onClick", function(evt) { editToolbar.deactivate(); }); createMapMenu(); createGraphicsMenu(); }
function createGraphicsMenu() { // Creates right-click context menu for GRAPHICS ctxMenuForGraphics = new dijit.Menu({}); ctxMenuForGraphics.addChild(new dijit.MenuItem({ label: "Edit", onClick: function() { if (selected.geometry.type !== "point") { editToolbar.activate(esri.toolbars.Edit.EDIT_VERTICES, selected); } else { alert("Not implemented"); } } })); ctxMenuForGraphics.addChild(new dijit.MenuItem({ label: "Move", onClick: function() { editToolbar.activate(esri.toolbars.Edit.MOVE, selected); } })); ctxMenuForGraphics.addChild(new dijit.MenuItem({ label: "Rotate/Scale", onClick: function() { if (selected.geometry.type !== "point") { editToolbar.activate(esri.toolbars.Edit.ROTATE | esri.toolbars.Edit.SCALE, selected); } else { alert("Not implemented"); } } })); ctxMenuForGraphics.addChild(new dijit.MenuSeparator()); ctxMenuForGraphics.addChild(new dijit.MenuItem({ label: "Delete", onClick: function() { userGraphics.remove(selected); if (selected.attributes.newID) { localStorage.removeItem(selected.attributes.newID); } else { localStorage.removeItem(localStorage.key(selected.attributes.LSNo)); } } })); ctxMenuForGraphics.startup(); dojo.connect(userGraphics, "onMouseOver", function(evt) { // We'll use this "selected" graphic to enable editing tools // on this graphic when the user click on one of the tools // listed in the menu. selected = evt.graphic; // Let's bind to the graphic underneath the mouse cursor ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode()); }); dojo.connect(userGraphics, "onMouseOut", function(evt) { ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode()); }); }
