As he stated, sachin was able to resolve his problem by defining an appropriate datum transformation for layers in his map document prior to publishing his map service.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
GIS Manual: Why Don;t My GIS Layers Line Up?
I am having the same issue. Can you remember what you did to fix the error?
Thank you
ahh! thanks for clarifying 🙂if thats the case, the same misalignment should appear in the REST service's JavaScript Viewer and even in the map document used to publish the service.can you confirm whether or not that is the case and check the coordinate system of the actual data?
how could you judge alignment until you were overlaying two different services?i could be wrong, but i doubt that version compatibility is the problem here.
what are the coordinate systems (and more importantly underlying datums) of the two services?
