I have a point file that is spread over the state
I want to create a heat map based on a count field in the point data.
From there I want to create a polygon layer that shows the rings.
What I want is a value associated with the rings themselves...say 1-5 depending on the heat map/ kernel density representation.
I can then use those polygon rings for search/select boundaries
I tried to use Kernel density
I then try to convert to polygon and says invalid GP Type. I used the int function in tools and it only creates a single record....Very confused..
Any thoughts?
