import arcpy from arcpy import env arcpy.env.workspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script" outworkspace = r"C:\GIS\Projekti\Divaca_Ber_10ocen_met9\Testno\script\point" rasterlist = arcpy.ListRasters("*") for raster in rasterlist: arcpy.RasterToPoint_conversion(raster, outworkspace + "//" + str(raster) + ".shp", "VALUE")
#import libraries import arcpy from arcpy import env #set environments arcpy.env.workspace = r'[file path to where your rasters are stored] outworkspace = r'[file path to where you want to save outputs] #create list rasterlist = arcpy.ListRasters("*") #loop thru list for raster in rasterlist: arcpy.RasterToPoint_conversion(rasterlist, outworkspace + "//" + str(raster) + "_point", "VALUE") #this confirms you are looking at the VALUE field of the raster, and calling the output file the same name as the raster, appended by _point. del outworkspace, raster, rasterlist
