This is the link for the question!
Thanks in advance!
Pedro,
Here is your code working:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Multiple Routes</title> <link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css"> <script src="https://js.arcgis.com/3.17/"></script> <script> var map; // var sensors = getSensors(); var sensorIndex = 0; require([ "esri/urlUtils", "esri/config", "esri/map", "esri/geometry/webMercatorUtils", "esri/graphic", "esri/SpatialReference", "esri/geometry/Point", "esri/tasks/RouteTask", "esri/tasks/RouteParameters", "esri/tasks/FeatureSet", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "dojo/_base/array", "dojo/on", "dojo/dom", "dijit/registry", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/HorizontalSlider", "dijit/form/HorizontalRuleLabels", "dojo/domReady!" ], function( urlUtils, esriConfig, Map, webMercatorUtils, Graphic, SpatialReference, Point, RouteTask, RouteParameters, FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol, Color, array, on, dom, registry, BorderContainer, ContentPane, HorizontalSlider, HorizontalRuleLabels ) { var map, routeTask, routeParams, routes = []; var stopSymbol, barrierSymbol, routeSymbols; var mapOnClick_addStops_connect, mapOnClick_addBarriers_connect; var x = -48.48; var y = -1.45; map = new Map("map", { basemap: "streets", center: [x, y], zoom: 15 }); routeTask = new RouteTask("https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World"); routeParams = new RouteParameters(); routeParams.stops = new FeatureSet(); routeParams.barriers = new FeatureSet(); routeParams.outSpatialReference = { "wkid": 102100 }; routeTask.on("solve-complete", showRoute); routeTask.on("error", errorHandler); stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15); stopSymbol.outline.setWidth(3); barrierSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_X).setSize(10); barrierSymbol.outline.setWidth(3).setColor(new Color([255, 0, 0])); routeSymbols = { "Route 1": new SimpleLineSymbol().setColor(new Color([0, 0, 255, 0.5])).setWidth(5), "Route 2": new SimpleLineSymbol().setColor(new Color([0, 255, 0, 0.5])).setWidth(5), "Route 3": new SimpleLineSymbol().setColor(new Color([255, 0, 255, 0.5])).setWidth(5) }; //button click event listeners can't be added directly in HTML when the code is wrapped in an AMD callback on(dom.byId("addStopsBtn"), "click", addStops); on(dom.byId("clearStopsBtn"), "click", clearStops); on(dom.byId("addBarriersBtn"), "click", addBarriers); on(dom.byId("clearBarriersBtn"), "click", clearBarriers); on(dom.byId("solveRoutesBtn"), "click", solveRoute); on(dom.byId("clearRoutesBtn"), "click", clearRoutes); function addBarriers() { removeEventHandlers(); addBarrier(); } //Adds a barrier function addBarrier() { var eventsArray = []; sensorArryay = getSensors(); routeParams.barriers = new FeatureSet(); for (var i = 0; i < sensorArryay.length; i++) { var pnt = new Point(sensorArryay.contextElement.attributes[2].value, sensorArryay.contextElement.attributes[1].value, new SpatialReference(4326)) routeParams.barriers.features.push(map.graphics.add(new esri.Graphic(webMercatorUtils.geographicToWebMercator(pnt), barrierSymbol))); } } //Begins listening for click events to add stops function addStops() { removeEventHandlers(); mapOnClick_addStops_connect = map.on("click", addStop); } //Clears all stops function clearStops() { removeEventHandlers(); for (var i = routeParams.stops.features.length - 1; i >= 0; i--) { map.graphics.remove(routeParams.stops.features.splice(i, 1)[0]); } } //Adds a stop. The stop is associated with the route currently displayed in the dropdown function addStop(evt) { routeParams.stops.features.push( map.graphics.add( new esri.Graphic( evt.mapPoint, stopSymbol, { RouteName: dom.byId("routeName").value } ) ) ); } //Clears all barriers function clearBarriers() { removeEventHandlers(); for (var i = routeParams.barriers.features.length - 1; i >= 0; i--) { map.graphics.remove(routeParams.barriers.features.splice(i, 1)[0]); } } //Stops listening for click events to add barriers and stops (if they've already been wired) function removeEventHandlers() { if (mapOnClick_addStops_connect) { mapOnClick_addStops_connect.remove(); } if (mapOnClick_addBarriers_connect) { mapOnClick_addBarriers_connect.remove(); } } //Solves the routes. Any errors will trigger the errorHandler function. function solveRoute() { removeEventHandlers(); routeTask.solve(routeParams); } //Clears all routes function clearRoutes() { for (var i = routes.length - 1; i >= 0; i--) { map.graphics.remove(routes.splice(i, 1)[0]); } routes = []; } //Draws the resulting routes on the map function showRoute(evt) { clearRoutes(); array.forEach(evt.result.routeResults, function(routeResult, i) { routes.push( map.graphics.add( routeResult.route.setSymbol(routeSymbols[routeResult.routeName]) ) ); }); var msgs = ["Server messages:"]; array.forEach(evt.result.messages, function(message) { msgs.push(message.type + " : " + message.description); }); if (msgs.length > 1) { alert(msgs.join("\n - ")); } } //Reports any errors that occurred during the solve function errorHandler(err) { alert("An error occured\n" + err.message + "\n" + err.details.join("\n")); } }); function getSensors() { var result = '{"contextResponses":[{"contextElement":{"type":"StreetFixed","isPattern":"false","id":"StreetFixed1","attributes":[{"name":"aircondition","type":"float","value":"66.1"},{"name":"lat","type":"float","value":"-1.4519538"},{"name":"lng","type":"float","value":"-48.4781193"},{"name":"temperature","type":"float","value":"29.8"}]},"statusCode":{"code":"200","reasonPhrase":"OK"}},{"contextElement":{"type":"StreetFixed","isPattern":"false","id":"StreetFixed2","attributes":[{"name":"aircondition","type":"float","value":"66.1"},{"name":"lat","type":"float","value":"-1.4519062"},{"name":"lng","type":"float","value":"-48.476207"},{"name":"temperature","type":"float","value":"29.8"}]},"statusCode":{"code":"200","reasonPhrase":"OK"}},{"contextElement":{"type":"StreetFixed","isPattern":"false","id":"StreetFixed3","attributes":[{"name":"aircondition","type":"float","value":"66.1"},{"name":"lat","type":"float","value":"-1.4518047"},{"name":"lng","type":"float","value":"-48.4744374"},{"name":"temperature","type":"float","value":"29.8"}]},"statusCode":{"code":"200","reasonPhrase":"OK"}},{"contextElement":{"type":"StreetFixed","isPattern":"false","id":"StreetFixed4","attributes":[{"name":"aircondition","type":"float","value":"66.1"},{"name":"lat","type":"float","value":"-1.4517104"},{"name":"lng","type":"float","value":"-48.4726244"},{"name":"temperature","type":"float","value":"29.8"}]},"statusCode":{"code":"200","reasonPhrase":"OK"}}]}'; // var request = new XMLHttpRequest(); // request.open('GET', '/getSensors', false); // `false` makes the request synchronous // request.send(null); // // if (request.status === 200) { // result = JSON.parse(request.responseText).contextResponses; // // console.log(result); // console.log("getSensors done!"); // } return JSON.parse(result).contextResponses; } function eventFire(el, etype) { if (el.fireEvent) { el.fireEvent('on' + etype); } else { var evObj = document.createEvent('Events'); evObj.initEvent(etype, true, false); el.dispatchEvent(evObj); } } </script> </head> <body class="claro"> Select route name: <select id="routeName"> <option value="Route 1">Route 1</option> <option value="Route 2">Route 2</option> <option value="Route 3">Route 3</option> </select> to <button id="addStopsBtn">Add Stops</button> <button id="clearStopsBtn">Clear Stops</button> <button id="addBarriersBtn">Add Barriers</button> <button id="clearBarriersBtn">Clear Barriers</button> <button id="solveRoutesBtn">Solve Routes</button> <button id="clearRoutesBtn">Clear Routes</button> <br /> <br /> <div id="map" style="width:600px; height:400px; border:1px solid #000;"></div> <ol> <li>Select a route name from the drop down.</li> <li>Click 'Add stops', then click on map to add stops to route.</li> <li>Click the 'Add Barriers', then click on map to add barriers.</li> <li>Optionally, repeat the above steps to add more routes.</li> <li>Click the 'Solve Routes' to solve.</li> </ul> <p>Any server error messages will be displayed in an alert box.</p> </body> </html>
Thank you Robert!
I'll check out to see how does it work looking at the references.
As you may suppose, I'm using a local server to request the sensors from a cloud server. The getSensor() method returns this JSON file shown below. You may create a sample of this.
This is the array of sensors in JSON format:
{ "contextResponses": [4] 0: { "contextElement": { "type": "StreetFixed" "isPattern": "false" "id": "StreetFixed1" "attributes": [4] 0: { "name": "aircondition" "type": "float" "value": "66.1" }- 1: { "name": "lat" "type": "float" "value": "-1.4519538" }- 2: { "name": "lng" "type": "float" "value": "-48.4781193" }- 3: { "name": "temperature" "type": "float" "value": "29.8" }- - }- "statusCode": { "code": "200" "reasonPhrase": "OK" }- }- 1: { "contextElement": { "type": "StreetFixed" "isPattern": "false" "id": "StreetFixed2" "attributes": [4] 0: { "name": "aircondition" "type": "float" "value": "66.1" }- 1: { "name": "lat" "type": "float" "value": "-1.4519062" }- 2: { "name": "lng" "type": "float" "value": "-48.476207" }- 3: { "name": "temperature" "type": "float" "value": "29.8" }- - }- "statusCode": { "code": "200" "reasonPhrase": "OK" }- }- 2: { "contextElement": { "type": "StreetFixed" "isPattern": "false" "id": "StreetFixed3" "attributes": [4] 0: { "name": "aircondition" "type": "float" "value": "66.1" }- 1: { "name": "lat" "type": "float" "value": "-1.4518047" }- 2: { "name": "lng" "type": "float" "value": "-48.4744374" }- 3: { "name": "temperature" "type": "float" "value": "29.8" }- - }- "statusCode": { "code": "200" "reasonPhrase": "OK" }- }- 3: { "contextElement": { "type": "StreetFixed" "isPattern": "false" "id": "StreetFixed4" "attributes": [4] 0: { "name": "aircondition" "type": "float" "value": "66.1" }- 1: { "name": "lat" "type": "float" "value": "-1.4517104" }- 2: { "name": "lng" "type": "float" "value": "-48.4726244" }- 3: { "name": "temperature" "type": "float" "value": "29.8" }- - }- "statusCode": { "code": "200" "reasonPhrase": "OK" }- }- - }
Here is the uncomment code as requested:
function getSensors(){ var result; var request = new XMLHttpRequest(); request.open('GET', '/getSensors', false); if (request.status === 200) { result = JSON.parse(request.responseText).contextResponses; console.log(result); console.log("getSensors done!"); } return result; }
Thanks!
What does your sensor data look like? As I do not have access to your sensor service I need to replicate the data to test your app. Can you un-comment the console.log(result) and copy that data and post for me?
Here is the .js code used to run the service:
var map; // var sensors = getSensors(); var sensorIndex = 0; require([ "esri/urlUtils", "esri/config", "esri/map", "esri/geometry/webMercatorUtils", "esri/graphic", "esri/tasks/RouteTask", "esri/tasks/RouteParameters", "esri/tasks/FeatureSet", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "dojo/_base/array", "dojo/on", "dojo/dom", "dijit/registry", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/HorizontalSlider", "dijit/form/HorizontalRuleLabels", "dojo/domReady!" ], function ( urlUtils, esriConfig, Map, webMercatorUtils, Graphic, RouteTask, RouteParameters, FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol, Color, array, on, dom, registry, BorderContainer, ContentPane, HorizontalSlider, HorizontalRuleLabels ) { var map, routeTask, routeParams, routes = []; var stopSymbol, barrierSymbol, routeSymbols; var mapOnClick_addStops_connect, mapOnClick_addBarriers_connect; var x = -48.48; var y = -1.45; map = new Map("map", { basemap: "streets", center: [x, y], zoom: 15 }); routeTask = new RouteTask("https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World"); routeParams = new RouteParameters(); routeParams.stops = new FeatureSet(); routeParams.barriers = new FeatureSet(); routeParams.outSpatialReference = {"wkid":102100}; routeTask.on("solve-complete", showRoute); routeTask.on("error", errorHandler); stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15); stopSymbol.outline.setWidth(3); barrierSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_X).setSize(10); barrierSymbol.outline.setWidth(3).setColor(new Color([255,0,0])); routeSymbols = { "Route 1": new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(5), "Route 2": new SimpleLineSymbol().setColor(new Color([0,255,0,0.5])).setWidth(5), "Route 3": new SimpleLineSymbol().setColor(new Color([255,0,255,0.5])).setWidth(5) }; //button click event listeners can't be added directly in HTML when the code is wrapped in an AMD callback on(dom.byId("addStopsBtn"), "click", addStops); on(dom.byId("clearStopsBtn"), "click", clearStops); on(dom.byId("addBarriersBtn"), "click", addBarriers); on(dom.byId("clearBarriersBtn"), "click", clearBarriers); on(dom.byId("solveRoutesBtn"), "click", solveRoute); on(dom.byId("clearRoutesBtn"), "click", clearRoutes); document.getElementById("map").addEventListener("click", function(evt){ // console.log("This is a CLONE event: "); // console.log(evt); // console.log(" - - - - - - -"); // evt = changeParams(evt, sensorIndex); // console.log(evt); // console.log("\n"); // console.log("\n"); // console.log("\n"); // console.log("======="); // addBarrier(evt); // sensorIndex++; // if(sensorIndex > sensors.length) // sensorIndex = 0; }); function addBarriers() { removeEventHandlers(); mapOnClick_addBarriers_connect = on(map, "click", addBarrier); } //Adds a barrier function addBarrier(evt) { var eventsArray = []; sensorArryay = getSensors(); routeParams.barriers = new FeatureSet(); for(var i = 0; i < sensorArryay.length; i++){ var obj = jQuery.extend(true, {}, evt); eventsArray.push(obj); } for (var i = 0; i < sensorArryay.length; i++) { [eventsArray.mapPoint.x,eventsArray.mapPoint.y]=webMercatorUtils.lngLatToXY( sensorArryay.contextElement.attributes[2].value, sensorArryay.contextElement.attributes[1].value ); routeParams.barriers.features.push(map.graphics.add(new esri.Graphic(eventsArray.mapPoint,barrierSymbol))); } } //Begins listening for click events to add stops function addStops() { removeEventHandlers(); mapOnClick_addStops_connect = map.on("click", addStop); } //Clears all stops function clearStops() { removeEventHandlers(); for (var i=routeParams.stops.features.length-1; i>=0; i--) { map.graphics.remove(routeParams.stops.features.splice(i, 1)[0]); } } //Adds a stop. The stop is associated with the route currently displayed in the dropdown function addStop(evt) { routeParams.stops.features.push( map.graphics.add( new esri.Graphic( evt.mapPoint, stopSymbol, { RouteName:dom.byId("routeName").value } ) ) ); } //Clears all barriers function clearBarriers() { removeEventHandlers(); for (var i=routeParams.barriers.features.length-1; i>=0; i--) { map.graphics.remove(routeParams.barriers.features.splice(i, 1)[0]); } } //Stops listening for click events to add barriers and stops (if they've already been wired) function removeEventHandlers() { if (mapOnClick_addStops_connect) { mapOnClick_addStops_connect.remove(); } if (mapOnClick_addBarriers_connect) { mapOnClick_addBarriers_connect.remove(); } } //Solves the routes. Any errors will trigger the errorHandler function. function solveRoute() { removeEventHandlers(); routeTask.solve(routeParams); } //Clears all routes function clearRoutes() { for (var i=routes.length-1; i>=0; i--) { map.graphics.remove(routes.splice(i, 1)[0]); } routes = []; } //Draws the resulting routes on the map function showRoute(evt) { clearRoutes(); array.forEach(evt.result.routeResults, function(routeResult, i) { routes.push( map.graphics.add( routeResult.route.setSymbol(routeSymbols[routeResult.routeName]) ) ); }); var msgs = ["Server messages:"]; array.forEach(evt.result.messages, function(message) { msgs.push(message.type + " : " + message.description); }); if (msgs.length > 1) { alert(msgs.join("\n - ")); } } //Reports any errors that occurred during the solve function errorHandler(err) { alert("An error occured\n" + err.message + "\n" + err.details.join("\n")); } }); function getSensors(){ var result; var request = new XMLHttpRequest(); request.open('GET', '/getSensors', false); // `false` makes the request synchronous request.send(null); if (request.status === 200) { result = JSON.parse(request.responseText).contextResponses; // console.log(result); console.log("getSensors done!"); } return result; } function eventFire(el, etype){ if (el.fireEvent) { el.fireEvent('on' + etype); } else { var evObj = document.createEvent('Events'); evObj.initEvent(etype, true, false); el.dispatchEvent(evObj); } }
Are you clearing the maps graphics in your code some where? Maybe it would be good to post your whole modified code.
