Is it possible to read a local asset (.glb file) as a symbol into a SceneView in a Xamarin.Android AR project? I'm using the Android template from here - ArcGIS Runtime SDK for .NET - AR Templates - Visual Studio Marketplace
Here's the code, I get a File Not Found error on the ModelSceneSymbol.CreateAsync() line.
GraphicsOverlay planeOverlay = new GraphicsOverlay();
planeOverlay.SceneProperties.SurfacePlacement = SurfacePlacement.Relative;
arSceneView.GraphicsOverlays.Add(planeOverlay);
Uri modelSourceUri = new Uri(@ms-appx:///Assets/Duck.glb);
var modelSymbol = await ModelSceneSymbol.CreateAsync(modelSourceUri, 1000);
MapPoint location = new MapPoint(-71.0096, 42.3656, 20, SpatialReferences.Wgs84);
Graphic modelGraphic = new Graphic(location, modelSymbol);
planeOverlay.Graphics.Add(modelGraphic);
The asset is in the Assets folder in the project. I've tried different BuildActions on the file (AndroidAsset, Content), no luck. I've tried different Uri schemes (file:///) without luck. I've also tried loading the asset from a url. In this case I don't get an error, but the model doesn't render.
The model I'm trying to load is this (also attached) - glTF-Sample-Models/Duck.glb at master · KhronosGroup/glTF-Sample-Models · GitHub
For reference, in a WPF app I was able to do the same thing successfully with more or less the same code. So essentially if its possible, what is the correct way to create a Uri to an asset?
Chris
