//map load complete private function mapLoadComplete(event:MapEvent):void { try { if (ExternalInterface.available) { var result:URLVariables = new URLVariables(); var urlSubstring:String = ExternalInterface.call("window.location.search.substring", 1); if (urlSubstring && urlSubstring.length > 0 && urlSubstring != "debug=true") { result.decode(urlSubstring); // Parse URL var xExt:String; var xUrlParam:String; var yLat:String; var xLon:String; var mScale:String; if (result["EXT"]) xExt = result.EXT; if (result["LAT"]) yLat = result.LAT; if (result["LON"]) xLon = result.LON; if (result["SCALE"]) mScale = result.SCALE; if(!yLat == "" && !xLon == "") { var spatRef:SpatialReference = new SpatialReference(4326); var cPoint:MapPoint = new MapPoint(parseFloat(xLon), parseFloat(yLat),spatRef); if(!mScale==""){ map.scale = parseInt(mScale); }else{ map.scale = 20000; } if (map.spatialReference.wkid != 4326) { map.cursorManager.setBusyCursor(); var geomServ:GeometryService = new GeometryService("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); geomServ.addEventListener(GeometryServiceEvent.PROJECT_COMPLETE,pResult); geomServ.addEventListener(FaultEvent.FAULT,pFault); geomServ.project([cPoint],map.spatialReference); function pResult(event:GeometryServiceEvent):void{ var pt:MapPoint = (event.result as Array)[0]as MapPoint; map.centerAt(pt); map.cursorManager.removeBusyCursor(); } function pFault(err:Object):void{ map.cursorManager.removeBusyCursor(); } } else{ map.centerAt(cPoint); } } if (!xExt == ""){ var extArray:Array = xExt.split(","); var extent:Extent = new Extent(Number(extArray[0]), Number(extArray[1]), Number(extArray[2]), Number(extArray[3]),map.spatialReference); map.extent = extent; } } } } catch (error:Error){} }
import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.tasks.GeometryService; import com.esri.ags.geometry.Geometry;
I would like a field in our access database to contain a hyperlink that has co-ordinates in which in turn opens up a new webpage to the flexveiwer
