Hello Everybody,
I have a huge Shapefile in which I want to remove sliver polygons with the eliminate tool in python. However, repeatedly get the following error. At first i tried to execute without the "layer", but otherwise, the "SelectLayerByAttribute_management" returns an error (altough it works with the GUI on the Shapefile directly).
I am quite new to ArcGIS scripting and really hope to get some hints.
thank you and regards,
Ludwig
"File "remove_slivers_and_gaps.py", line 26, in <module>
arcpy.Eliminate_management(in_features = "layer", out_feature_class = output
shapefile, selection = "AREA", ex_where_clause = ' "Vegetation" = 5 ')
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\management.py", line 4233, in Eliminate
raise e
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000670: output Output Feature Class is same as input Input Layer
failed to execute (Eliminate)."
My Script ist here:
inputshapefile = "Vegetation_25832.shp"
workshapefile = "work_25832.shp"
outputshapefile = "Vegetation_rsag_25832.shp"
env.workspace = "D:\\R_working_directory\\remove_gaps_slivers"
### Repair geometry
arcpy.RepairGeometry_management(in_features = inputshapefile)
### Multipart to Singlepart
arcpy.MultipartToSinglepart_management(in_features = inputshapefile,
out_feature_class = workshapefile)
### Add new Field for area
arcpy.AddField_management(in_table = workshapefile, field_name = "area",
field_type = "FLOAT", field_precision = 10, field_scale = 2)
### Calculate new Field with area
arcpy.CalculateField_management(in_table = workshapefile,
field = "area", expression = '!shape.area@meters!', expression_type = "PYTHON")
### Execute SelectLayerByAttribute to define features to be eliminated
arcpy.MakeFeatureLayer_management(in_features = workshapefile, out_layer = "layer")
arcpy.SelectLayerByAttribute_management(in_layer_or_view = "layer",
selection_type = "NEW_SELECTION", where_clause = ' "area" < 1 ')
### Execute Eliminate
arcpy.Eliminate_management(in_features = "layer", out_feature_class = outputshapefile,
Message was edited by: Curtis Price - added python code highlighting and wrapped some lines
