C:\>sdelayer -o alter Error: Table name and spatial column must be specified. Must specify layer parameter for ALTER operation. ArcSDE 10.1 Layer Administration Utility ----------------------------------------------------- sdelayer -o alter -l <table,column> [-e <entity_mask>] [-M <minimum_id>] [-S <layer_description_str>] [-k <config_keyword>] [-i <service>] [-s <server_name>] [-D <database>] [Spatial_Index] [-L <ON | OFF>] [-E {empty | calc | xmin,ymin,xmax,ymax}] [-P HIGH [{-R <SRID> | [Spatial_Ref_Opts2]}]] [-u <DB_User_name>] [-p <DB_User_password>] [-N] [-q] Where [Spatial_Ref_Opts2]:= [-x <xoffset,yoffset,xyscale>] [-z <zoffset,zscale>] [-m <moffset,mscale>] [-G {<projection_ID> | file=<proj_file_name>}] [Spatial_Index] := [-g {<Grid_Options> | GRID,<Grid_Options> | AUTOMATIC | NONE | RTREE}] [Grid_Options] := [<grid_sz0>[,<grid_sz1>[,<grid_sz2>]] [,{FULL | SPARSE}]] sdelayer -h sdelayer -?
C:\>sdelayer -o describe_long -i ora100 -u staff -p ***** -l census_bg1a,shape ArcSDE 10.0 for Oracle11g Build 775 Fri Sep 17 11:45:27 2010 Layer Administration Utility ----------------------------------------------------- Layer Description ....: <None> Table Owner ..........: STAFF Table Name ...........: CENSUS_BG1A Spatial Column .......: SHAPE Layer Id .............: 14 SRID .................: 5 Auth SRID.............: 4 Minimum Shape Id .....: 1 Offset ...............: falsex: -400.000000 falsey: -400.000000 System Units .........: 1000000000.000000 Z Offset..............: 0.000000 Z Units ..............: 1.000000 Measure Offset .......: <None> Measure Units ........: <None> XY Cluster Tolerance .: 0.000000002 Spatial Index ........: parameter: SPIDX_GRID,GRID0=0.21,FULL exist: Yes array form: 0.21,0,0 Layer Envelope .......: minx: -179.14734, miny: -14.60526 maxx: 179.77847, maxy: 71.35256 Entities .............: na+ Layer Type ...........: SDE-LOB Creation Date ........: 05/24/11 16:11:57 I/O Mode .............: NORMAL Autolocking ..........: Disabled Precision.............: High User Privileges ......: SELECT, UPDATE, INSERT, DELETE Coordinate System ....: GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]] Layer Configuration ..: sdelob
