When there is no legend to display (e.g. layers are turned off or otherwise not visible) the legend div defaults to some text "No legend". I would like to change the text used. How do I do this?
Mark,
You will need to replace the default sting in the esriNLS strings:
sample snippet:
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/i18n!esri/nls/jsapi"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> bundle<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> bundle<SPAN class="punctuation token">.</SPAN>widgets<SPAN class="punctuation token">.</SPAN>legend<SPAN class="punctuation token">.</SPAN>NLS_noLegend <SPAN class="operator token">=</SPAN> <SPAN class="string token">"My No Legend"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Localization | Guide | ArcGIS API for JavaScript 3.19
