I am using this example to add a polygon: AND it works greathttp://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsAutoSaveI am referencing this example to open the data form to edit the data as soon as the feature is added...http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolkitFeatureDataFormWhile this works for the Point it is not working for the line and polygon....which require mutliple mouse downsIs there an event I can place on the Line adn Polygon Feature that when I add a new one i can open the data formIs there an Editstarted or similar that will allow me to run soem code as soon as I finish creating the feature?THanks<esri:FeatureLayer ID="MG_Polygon" Visible="True" MouseLeftButtonUp="Poly_MouseLeftButtonUp" Url="http://156.555.555.189/ArcGIS/rest/services/TEST_FS/FeatureServer/24" DisableClientCaching="True" Mode="OnDemand" SelectionColor="#FFFFFF00" OutFields="*" />
Private Sub Poly_MouseLeftButtonUp(ByVal sender As Object, ByVal args As GraphicMouseButtonEventArgs) Dim featureLayer As FeatureLayer = TryCast(sender, FeatureLayer) For Each g As Graphic In featureLayer.Graphics If (g.Selected) Then g.UnSelect() End If Next args.Graphic.Select() MyPolygonFeatureDataForm.GraphicSource = args.Graphic PolygonDataFormBorder.Visibility = Visibility.Visible End Sub
Basically just trying to open the data form after the feature is added and allow the user t enter data....the way I hav it above you have to add the feature then click the new feature and then data form opens...for the line and polygon that is....adding a point it opens the data form....?????
