# -*- coding: utf-8 -*- """ This script will convert a table to an excel spreadsheet. If the third-party module xlwt is available, it will use that. Otherwise, it will fall back to CSV. """ import arcgisscripting import os gp = arcgisscripting.create(9.3) def header_and_iterator(dataset_name): """Returns a list of column names and an iterator over the same columns""" data_description = gp.Describe(dataset_name) fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]] def iterator_for_feature(): cursor = gp.SearchCursor(dataset_name) row = cursor.next() while row: yield [getattr(row, col) for col in fieldnames] row = cursor.next() del row, cursor return fieldnames, iterator_for_feature() def export_to_csv(dataset, output): """Output the data to a CSV file""" import csv def _encode(x): if isinstance(x, unicode): return x.encode("utf-8") else: return str(x) def _encodeHeader(x): return _encode(x.replace(".","_")) out_writer = csv.writer(open(output, 'wb')) header, rows = header_and_iterator(dataset) out_writer.writerow(map(_encodeHeader, header)) for row in rows: out_writer.writerow(map(_encode, row)) def export_to_xls(dataset, output): """ Attempt to output to an XLS file. If xmlwt is not available, fall back to CSV. XLWT can be downloaded from http://pypi.python.org/pypi/xlwt""" try: import xlwt except ImportError: gp.AddError("import of xlwt module failed") return header, rows = header_and_iterator(dataset) # Make spreadsheet workbook = xlwt.Workbook() worksheet = workbook.add_sheet(os.path.split(dataset)[1]) #Set up header row, freeze panes header_style = xlwt.easyxf("font: bold on; align: horiz center") for index, colheader in enumerate(header): worksheet.write(0, index, colheader.replace(".","_")) worksheet.set_panes_frozen(True) worksheet.set_horz_split_pos(1) worksheet.set_remove_splits(True) # Write rows for rowidx, row in enumerate(rows): for colindex, col in enumerate(row): worksheet.write(rowidx+1, colindex, col) # All done workbook.save(output) def reformat(output): import csv #read lines of CSV f = open(output, "r") lines=f.readlines() lines=lines[1:] f.close() #write all lines except header to CSV f = open(output, "w+") for line in lines: f.write(line) f.close() #remove first column with open(output,"r") as input: with open(output + "_1", "w+") as output2: writer=csv.writer(output2) for row in csv.reader(input): writer.writerow(row[1:]) #remove empty rows input = open(output + "_1", 'rb') output2 = open(output + "_2", 'wb') writer = csv.writer(output2) for row in csv.reader(input): if row: writer.writerow(row) input.close() output2.close() os.remove(output) os.remove(output + "_1") #rename to original CSV os.rename(output + "_2", output) if __name__ == "__main__": dataset_name = gp.GetParameterAsText(0) output_file = gp.GetParameterAsText(1) format = gp.GetParameterAsText(2) if format == "CSV": export_to_csv(dataset_name, output_file) reformat(output_file) elif format == "XLS": try: export_to_xls(dataset_name, output_file) except: import traceback gp.AddError(traceback.format_exc()) else: raise ValueError("Don't know how to export to %r" % format) print "FINISHED"
# -*- coding: utf-8 -*- """ This script will convert a table to an excel spreadsheet. If the third-party module xlwt is available, it will use that. Otherwise, it will fall back to CSV. """ import arcgisscripting import os gp = arcgisscripting.create(9.3) def header_and_iterator(dataset_name): """Returns a list of column names and an iterator over the same columns""" data_description = gp.Describe(dataset_name) fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]] def iterator_for_feature(): cursor = gp.SearchCursor(dataset_name) row = cursor.next() while row: yield [getattr(row, col) for col in fieldnames] row = cursor.next() del row, cursor return fieldnames, iterator_for_feature() def export_to_csv(dataset, output): """Output the data to a CSV file""" import csv def _encode(x): if isinstance(x, unicode): return x.encode("utf-8") else: return str(x) def _encodeHeader(x): return _encode(x.replace(".","_")) out_writer = csv.writer(open(output, 'wb')) header, rows = header_and_iterator(dataset) out_writer.writerow(map(_encodeHeader, header)) for row in rows: out_writer.writerow(map(_encode, row)) def export_to_xls(dataset, output): """ Attempt to output to an XLS file. If xmlwt is not available, fall back to CSV. XLWT can be downloaded from http://pypi.python.org/pypi/xlwt""" try: import xlwt except ImportError: gp.AddError("import of xlwt module failed") return header, rows = header_and_iterator(dataset) # Make spreadsheet workbook = xlwt.Workbook() worksheet = workbook.add_sheet(os.path.split(dataset)[1]) #Set up header row, freeze panes header_style = xlwt.easyxf("font: bold on; align: horiz center") for index, colheader in enumerate(header): worksheet.write(0, index, colheader.replace(".","_")) worksheet.set_panes_frozen(True) worksheet.set_horz_split_pos(1) worksheet.set_remove_splits(True) # Write rows for rowidx, row in enumerate(rows): for colindex, col in enumerate(row): worksheet.write(rowidx+1, colindex, col) # All done workbook.save(output) if __name__ == "__main__": dataset_name = gp.GetParameterAsText(0) output_file = gp.GetParameterAsText(1) format = gp.GetParameterAsText(2) if format == "CSV": export_to_csv(dataset_name, output_file) elif format == "XLS": try: export_to_xls(dataset_name, output_file) except: import traceback gp.AddError(traceback.format_exc()) else: raise ValueError("Don't know how to export to %r" % format) print "FINISHED"
# -*- coding: utf-8 -*- """ This script will convert a table to an excel spreadsheet. If the third-party module xlwt is available, it will use that. Otherwise, it will fall back to CSV. """ import arcgisscripting import os gp = arcgisscripting.create(9.3) def header_and_iterator(dataset_name): """Returns a list of column names and an iterator over the same columns""" data_description = gp.Describe(dataset_name) fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]] def iterator_for_feature(): cursor = gp.SearchCursor(dataset_name) row = cursor.next() while row: yield [getattr(row, col) for col in fieldnames] row = cursor.next() del row, cursor return fieldnames, iterator_for_feature() def export_to_csv(dataset, output): """Output the data to a CSV file""" import csv def _encode(x): if isinstance(x, unicode): return x.encode("utf-8") else: return str(x) def _encodeHeader(x): return _encode(x.replace(".","_")) out_writer = csv.writer(open(output, 'wb')) header, rows = header_and_iterator(dataset) out_writer.writerow(map(_encodeHeader, header)) for row in rows: out_writer.writerow(map(_encode, row)) def export_to_xls(dataset, output): """ Attempt to output to an XLS file. If xmlwt is not available, fall back to CSV. XLWT can be downloaded from http://pypi.python.org/pypi/xlwt""" try: import xlwt except ImportError: gp.AddError("import of xlwt module failed") return header, rows = header_and_iterator(dataset) # Make spreadsheet workbook = xlwt.Workbook() worksheet = workbook.add_sheet(os.path.split(dataset)[1]) #Set up header row, freeze panes header_style = xlwt.easyxf("font: bold on; align: horiz center") for index, colheader in enumerate(header): worksheet.write(0, index, colheader.replace(".","_")) worksheet.set_panes_frozen(True) worksheet.set_horz_split_pos(1) worksheet.set_remove_splits(True) # Write rows for rowidx, row in enumerate(rows): for colindex, col in enumerate(row): worksheet.write(rowidx+1, colindex, col) # All done workbook.save(output) if __name__ == "__main__": dataset_name = gp.GetParameterAsText(0) output_file = gp.GetParameterAsText(1) format = gp.GetParameterAsText(2) if format == "CSV": export_to_csv(dataset_name, output_file) elif format == "XLS": try: export_to_xls(dataset_name, output_file) except: import traceback gp.AddError(traceback.format_exc()) else: raise ValueError("Don't know how to export to %r" % format) print "Finished" #start new script import csv, os table = r"C:\temp\python\XY.csv" outFile = r"C:\temp\python\XY_1.csv" outFile2 = r"C:\temp\python\XY_2.csv" #read lines of CSV f = open(table, "r") lines=f.readlines() lines=lines[1:] f.close() #write all lines except header to CSV f = open(table, "w+") for line in lines: f.write(line) f.close() #remove first column with open(table,"r") as input: with open(outFile,"w+") as output: writer=csv.writer(output) for row in csv.reader(input): writer.writerow(row[1:]) #remove empty rows input = open(outFile, 'rb') output = open(outFile2, 'wb') writer = csv.writer(output) for row in csv.reader(input): if row: writer.writerow(row) input.close() output.close() os.remove(table) os.remove(outFile) #rename to original CSV os.rename(outFile2, table) print "Finished"
