I am writing a code too fill combo box values to a form but I encounter the error that the registry is not defined even though it has been defined on line 40... Suggestions? Thank you.
require([ "dojo/ready",
"dojo/on",
"dojo/_base/connect",
"dojo/dom",
"dijit/registry",
"dojo/dom-construct",
"dojo/parser",
"esri/arcgis/utils",
"esri/domUtils",
"esri/tasks/query", 'dijit/_WidgetsInTemplateMixin',
'dojox/xml/parser', 'dojox/data/XmlStore',
'esri/tasks/QueryTask',"dijit/Menu",
"dijit/MenuItem",'dijit/form/Select',
"dojo/domReady!"], function(
ready,
on,
connect,
dom,
registry,
domConstruct,
parser,
arcgisUtils,
domUtils,
Query, _WidgetsInTemplateMixin, parser,
xmlParser, XmlStore,
QueryTask, Menu, MenuItem, Select
parser.parse();
fillcountyselect();
function fillcountyselect(){
var select1 = registry.byId("countyfield");
select1.addOption( {label:"Select County", value: 0});
