Hi,Some links for this problem :[INDENT]http://support.esri.com/en/bugs/nimbus/TklNMDY4OTMz[/INDENT][INDENT]http://support.esri.com/en/bugs/nimbus/TklNMDcxOTY0[/INDENT][INDENT]http://support.esri.com/en/bugs/nimbus/TklNMDc2MTg2[/INDENT]ByeChris
Just bumped into this tonight. Working with SSURGO data, the primary key is a numeric value, though stored in the field as a string... No idea why... With the exact same table, I was able to use Join Field to permanently append the fields from another table. Went to do it a second time. All settings the same... Failed every time I tried. I had the full target table selected, I was doing it manually directly through toolbox, and I was nowhere near the ~255 column cap... Tried it with only one field, still not working. Was able to use Join function through right-click menu just fine. Only error generated was 999999 generic error code. No other messages, or indication in logs of what might have produced this failure. Saw a few other posts addressing this issue for slightly different reasons. Wanted to tag onto this post to let people know it may still be an ongoing issue? No clear indication here if it was ever resolved...
Nothing above in this thread about 999999 crashes, just matches not working.
999999 crashes often are related to system related issues, often invalid path names, table names, and field names.
Ah yes. Thank you! I'm conflating forum posts after surfing a bunch related to same thing. The tables, filepath, field names all check out. Haven't changed anything from raw SSURGO tables, no hidden spaces, and the table that successfully joined using join field tool is in exact same location/gDB/filepath as the table that would not join successfully to the target table... Standard Join tool works from right click menu. Join Field tool through toolbox does not... I can't think of anything else that points to anything other than the tool itself? Though I am new. Any ideas if it's not the filepath/fieldnames etc?
I also did have a glitch earlier in the same process where I had to start again with raw data because the Join Field tool resulted in large amounts of blank (not Null but truly blank) cells that I knew should have data in them post-Join. At the time, I assumed it was me, but after ongoing issues and seeing this thread, I'm starting to think it may be more than just user-error... Thanks in advance for any possible help!
If you really are seeing crashes, i would contact Esri support. Though you are likely to find out it is a data specific issue. I have not non-data specific issues with Join Field except of course its legendary slowness.
SSURGO data retrievals can be very complicated, if you are using the soils records you can have a double one to many relationship between the map unit table, soil records, and layer records. Here are some pre-digested datasets that may save you some pain:
SSURGO Data Downloader (beta)
Area- and Depth-Weighted Averages of Selected SSURGO Variables for the Conterminous United States and District of Columb…
How bad is this software that it can't join two databases together? How bad is this company that 8 years go by with no fix?
I'm sorry you feel that way.
We went back to the original NIMBUS bug case listed above and tested with the same data using new software versions (namely ArcGIS Pro), and the Join Field tool correctly joins all attribute values from the join table to the input table, without nulls. The only nulls are those which were already in the join table. If you have a case that still isn't working please upload it here or contact tech support.
The top table is the input to Join Field (a feature class), bottom table is the join table. All the joined fields in the top have values, except where the join table has pre-existing nulls.
Still the same problem. After joining two tables (feature and table) in the same fGD no information in table, grayed menus and running circle in the corner. It seams that development is like a cycle. Arcview good and usable was from version 3.0. Maybe with ArcGIS PRO v. 3 will be the same.
Suggest patience (Join Field is fairly slow with large tables, and Pro runs all tools in the background so the application remains responsive) or do a dynamic join with Add Join followed by Copy Features (much faster).
If you still have a problem, I beg of you to contact Esri support, because believe it or not, that's how things get fixed, when people send real data to Esri that does not work. (Without 'real data' that fails, it is very hard for them to make progress improving quality.)
I'm still seeing problems with this as of 10.6. I still have to use a numeric field for it to run as expected.
I just had an issue with joins that aligns with this post, but I was able to figure it out. I will explain below; read bold text for quick issue and solution. I was using ArcGIS Pro 2.5.
I was trying to join data TO a standalone table FROM a geocoded feature class. I don't do this often, but I find it helpful when needing to geocode many records to cities/POI that have multiple duplicate geocoding locations in the data. By running Summary Statistics, I get unique locations and significantly save AGO credits when I geocode them (e.g. I had ~3.1 million records which cost ~124K credits - which I do not have - and reduced the locations to less than ~5,500 records at 220 credits, which I can manage!!). I then join the XY fields and map all original records the using the XY Table to Point tool. In theory, you can also use Make Query Table, but it isn't consistent either...and can be slow with larger datasets. This joining workflow seems to work better.
When I tried to join the data, using either the Add Join or the Join Field tools, it resulted in the joined fields from the geocoded FC to return <Null> for all values in the join fields. I think this should be allowed, so this may be a bug/issue for Esri to explore. My workaround was to convert the geocoded FC to a standalone table then join, and everything worked fine.
Hope this is helpful for this thread.
I highly recommend (plead with you really) to report the bug to Esri support. Reproducible user-reported bugs are the ones that get fixed.
