this call to distance function in the geometry service is returning INF .. does anyone knows what it is and why??
After that since it's not a double it breaks my json mapping
Distance (GeometryServer)
sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer/distance?sr=4326&geometry1=%7B%27geometryType%27%3A%27esriGeometryPoint%27%2C%27geometry%27%3A%7B%27x%27%3A-84.346539%2C%27y%27%3A33.886364%2C%27spatialReference%27%3A%7B%27wkid%27%3A4326%7D%7D%7D&geometry2=%7B%27geometryType%27%3A%27esriGeometryPolygon%27%2C%27geometry%27%3A%7B%27rings%27%3A%5B%5B%5B-84.347946%2C+33.89275%5D%2C+%5B-84.347946%2C+33.892723%5D%2C+%5B-84.347946%2C+33.892754%5D%2C+%5B-84.347946%2C+33.89275%5D%5D%5D%7D%7D&geodesic=true&distanceUnit=9002&f=html
Hello Walter,
The issue is the conflict of spatial reference and Distance Unit.
In your request, the Spatial reference was 4326 WGS - 84, which is Geographic Coordinate System (GCS), in angular unit. However your Distance Unit was 9002, which is international foot, in linear unit.
Based on documentation, If distanceUnit is not specified, the distance is in the units of the given spatial reference. If distanceUnit is specified, the unit must be compatible with the given spatial reference. That is, if sr is a PCS, then distanceUnit must be linear. If sr is a GCS, then distanceUnit must be angular.
If you remove distance unit from your REST endpoint, you will get the results.
Distance
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Distance/02r3000000z3000000/
esriUnitType
http://resources.arcgis.com/en/help/arcobjects-cpp/componenthelp/index.html#/esriSRUnitType_Constants/000w00000042000000/
GCS
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Geographic_coordinate_systems/02r300000105000000/
Hope the information is helpful.
Harvey
Not really.. I think the problem is the geometry but I wonder what the INF is.. if you do the exact same query with another geometry it'll return the result (I have been testing this a lot)Distance (GeometryServer)
