Going through the Tutorials | ArcGIS API for JavaScript and tried to display my map using the template code in the sandbox site (ArcGIS API for JavaScript Sandbox), but it won't take. I made sure my web map was public and I got someone else to test it as well.
Hi Ben Gardner,
I was able to reproduce the same behavior using your webmap. I saved a copy of your webmap and was able to reproduce there as well.
When watching the network traffic, I noticed that it was running into some trouble reading a directory on your ArcGIS Server.
I hope this helps!
Hmm. I wonder if it's because I imported a base map from our internal web server when I initially put the map together.
Thanks Alexander. Gives me a little more insight into the ArcGIS API.
map ID: acae825ec19046f1b1923d24e435f30a
Here's the code:
<!DOCTYPE html>
<html>
<head>
<title>Create a Web Map</title>
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<style>
html,body,#mapDiv,.map.container{
padding:0;
margin:0;
height:100%;
</style>
<script>var dojoConfig = { parseOnLoad:true };</script>
<script src="http://js.arcgis.com/3.10compact/"></script>
<script>
var map;
require([
"esri/map",
"esri/arcgis/utils",
"dojo/domReady!"
], function(Map, arcgisUtils){
arcgisUtils.createMap("acae825ec19046f1b1923d24e435f30a", "mapDiv").then(function (response) {
map = response.map;
</script>
</head>
<body>
<div id="mapDiv"></div>
</body>
</html>
Hello
What is your webmap id so we can test on our end.
Thanks!
