I'm having an issue with using Arcobjects to expand/collapse maps (data frames) in the TOC based on a selected value in a combo box. When a user changes the selection in the combo box, all maps should collapse except for the map that shares a name with the selected combo box. This works well with 1 or 2 maps in the document. With each additional map beyond 2, the last map added does not collapse.For example, assume 2 maps - Map A and Map B. Expand collapse works well. If I add Map C and change the combo box to "Map A", only Map B collapses. If I add Map D and then change the combo box to "Map B", all maps collapse except Maps B and D. private void expandScenario(string scenarioName) { //collapse all data frames for (int i = 0; i < m_maps.Count; i++) { m_maps.Item.Expanded = false; } //expand the scenario's data frame for (int i = 0; i < m_maps.Count; i++) { if (m_maps.Item.Name == scenarioName) { m_maps.Item.Expanded = true; } } activateDataFrame(scenarioName); }I have ensured that the document is being updated via IMxDocument.UpdateContents() after making the call. I've checked to make sure the m_maps.Count accurately reflects the number of data frames. I have also checked to make sure m_maps.Item.Expanded = false is being run on the data frame that fails to collapse.
I have noticed that the data frame in question collapses immediately if I move its position in the TOC - perhaps I need to refresh the TOC but I thought calling IMxDocument.UpdateContents() took care of that.
