Trying to run a geoprocessing task as in this example.The tool fails when submitted for execution with below error
"System.ArgumentException: Only 'http' and 'https' schemes are allowed.Parameter name: requestUri at System.Net.Http.HttpRequestMessage.InitializeValues(HttpMethod method, Uri requestUri) at System.Net.Http.HttpRequestMessage..ctor(HttpMethod method, Uri requestUri) at System.Net.Http.HttpClient.GetAsync(Uri requestUri, HttpCompletionOption completionOption, CancellationToken cancellationToken) at Esri.ArcGISRuntime.Http.ArcGISHttpClient.GetOrPostAsync(String requestUri, IEnumerable`1 parameters, CancellationToken cancellationToken, Boolean forcePost, HttpCompletionOption completionOption) at Esri.ArcGISRuntime.Tasks.Geoprocessing.Geoprocessor.<ExecuteInternal>d__0.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult() at ArcGISRuntimeSDKDotNet_DesktopSamples.Samples.MyRaster.<ViewshedButton_Click>d__5.MoveNext() in C:\\Raster1\\Contour\\MainWindow.xaml.cs:line 82"
private string gpkPath = @C:\sapyexamples\contour\contour.gpk;
private string gpUrl = string.Empty;
try
var gpService = new Esri.ArcGISRuntime.LocalServices.LocalGeoprocessingService(gpkPath, GeoprocessingServiceType.SubmitJobWithMapServerResult);
await gpService.StartAsync();
gpUrl = gpService.UrlGeoprocessingService;
var taskName = "contour";
// create Geoprocessor
var gp = new Geoprocessor(new Uri(gpkPath + "/" + taskName));
// set up the parameters - see serviceURL for parameter info
var parameter = new GPInputParameter();
var tifFile = new GPString("elevation", @..\..\raster\contourdata.gdb\elevation);
var interval = new GPString("Interval", "400");
var shpFile = new GPString("Contour_Result", @..\..\vector\scratch.gdb\aaaa.shp);
// add GPParameters to the parameter collection
parameter.GPParameters.Add(tifFile);
parameter.GPParameters.Add(interval);
parameter.GPParameters.Add(shpFile);
var result = await gp.ExecuteAsync(parameter);//FAILS HERE
MessageBox.Show("Success");
catch (Exception ex)
MessageBox.Show("No Luck");
MessageBox.Show(ex.ToString());
