Sorry for the slight delay in replying. That's really useful.Having seen what you have said about being able to use custom icons with the QueryTask, I thought I'd see if I could get it working - using the code that worked from the esri.request code.I get markers on the map, but they appear at 0,0 lat/long which is odd, and I'm not entirely sure why - I assume it's something to do with the wkid, but the code I'm using below seems correct - but obviously isn't!If I output the x/y/wikd I get: x - 456309, y - 520207 wkid - 3857 and these come from the layer. My base map is Bing, but I don't see how that would be a problem.Is there something obvious that I'm doing wrong which is making them appear at 0,0?Thanks. for (var i=0, il=resultFeatures.length; i<il; i++) { var point_x = resultFeatures.attributes.x; var point_y = resultFeatures.attributes.y; var point_wkid = resultFeatures.geometry.spatialReference.wkid; //console.log(point_x +" "+ point_y +" "+ point_wkid); var pointGraphic = new esri.Graphic(new esri.geometry.Point(point_x, point_y, new esri.SpatialReference({ wkid: point_wkid }) ), hmg.markers[4]); pointGraphic.setInfoTemplate(infoTemplate); map.graphics.add(pointGraphic); }
var requestHandle = esri.request({ url: url.path, //url is a variable for the whole querystring +&f=json content: url.query, //handleAs: "text", load: requestSucceeded, error: requestFailed }, {useProxy:true});
