I am making a call to arcpy.CopyRaster_management to convert some miscellaneous rasters into JPEG2000 *.jp2 files. Before making a call to this line, I want to set a few arcpy.env environment settings to be applied to the copy. Specifically, I would like to specify compression, pyramid, and tilesize.My code looks like the following:
# Specifying the environment settings
arcpy.env.workspace = outWorkspace
arcpy.env.tileSize = "512 512"
arcpy.env.compression = "JPEG2000 75"
arcpy.env.pyramid = "NONE"
#Copying the raster
arcpy.CopyRaster_management(filepath,name + ".jp2","DEFAULTS","0","0","","ColormapToRGB","8_BIT_UNSIGNED")
The actual raster copies, and is correct. However, my arcpy.env settings are not applied. For example, my tileSize is not set to the specified 512x512, and the *.ovr overviews file is created even though I specified for pyramids to not be created ("NONE").I am referencing the below document for CopyRaster_management: http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000094000000At the bottom of the document under "Environments" it lists the environment settings and the tileSize, compression, and pyramid options are listed, so I assume these should be getting applied. Am I applying these environment settings incorrectly? How can I prevent overviews from being created, and my tileSize from being correctly applied? Any help is appreciated, thanks.
