What is the least complex way to label a arcgisdynamic service layer that is using a map service comprised of two grids covering two counties with a minzoom of 40000? The label would be the id for each grid. Let me know if more information is needed.
Brandon,
Here is a sample.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>doctype html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjs.arcgis.com%2F3.24%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">http://js.arcgis.com/3.24/dijit/themes/claro/claro.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.24%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.24/esri/css/esri.css</A><SPAN>"</SPAN></SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #map <SPAN class="punctuation token">{</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.24%2F" target="_blank">https://js.arcgis.com/3.24/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> app <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ArcGISTiledMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/LayerDrawingOptions"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/LabelClass"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/TextSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> ArcGISTiledMapServiceLayer<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN> LayerDrawingOptions<SPAN class="punctuation token">,</SPAN> LabelClass<SPAN class="punctuation token">,</SPAN> TextSymbol<SPAN class="punctuation token">,</SPAN> parser <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>dataUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FCensus%2FMapServer%2F2" target="_blank">http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>defaultFrom <SPAN class="operator token">=</SPAN> <SPAN class="string token">"#ffffcc"</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>defaultTo <SPAN class="operator token">=</SPAN> <SPAN class="string token">"#006837"</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">85.787</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">39.782</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> slider<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> basemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISTiledMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fservices.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FWorld_Terrain_Base%2FMapServer" target="_blank">http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>basemap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> ref <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISTiledMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fservices.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FReference%2FWorld_Reference_Overlay%2FMapServer" target="_blank">http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> urlDyn <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FCensus%2FMapServer" target="_blank">http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN> usaLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN>urlDyn<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"us_counties"</SPAN><SPAN class="punctuation token">,</SPAN> opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.7</SPAN><SPAN class="punctuation token">,</SPAN> visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> usaLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setVisibleLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>usaLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> optionsArray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> drawingOptions <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDrawingOptions</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> labelClass <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LabelClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> labelExpression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'['</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"POP2000"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">']'</SPAN><SPAN class="punctuation token">,</SPAN> labelPlacement<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'esriServerPolygonPlacementAlwaysHorizontal'</SPAN><SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TextSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">840000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> drawingOptions<SPAN class="punctuation token">.</SPAN>labelingInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>labelClass<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> drawingOptions<SPAN class="punctuation token">.</SPAN>showLabels <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> optionsArray<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> drawingOptions<SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"us_counties"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setLayerDrawingOptions</SPAN><SPAN class="punctuation token">(</SPAN>optionsArray<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"us_counties"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline',gutters:false"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width: 100%; height: 100%; margin: 0;"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
my version is as follows:
Both set visible layers in the array are shown in the map although the label only shows for the 3rd layer in the array. Also the halo settings are not shown. What am I missing?
<SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">index_filenames</SPAN>").setLayerDrawingOptions(optionsArray);<CODE><SPAN style="color: #000000;"> </SPAN><SPAN style="color: #000000;">map</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit; font-size: 14px;">getLayer</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">"</SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">index_filenames</SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">"</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit; font-size: 14px;">show</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">}</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><CODE><SPAN style="color: #000000;">urlDyn </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;"><SPAN style="border: 0px; font-weight: inherit; font-size: 14px;">"<A href="https://sv07gdchfeat10.ct.dot.ca.gov/server/rest/services/D7Geospatial/CirgisLariacIndex2018" title="https://sv07gdchfeat10.ct.dot.ca.gov/server/rest/services/D7Geospatial/CirgisLariacIndex2018" rel="nofollow noopener noreferrer" target="_blank">https://sv07gdchfeat10.ct.dot.ca.gov/server/rest/services/D7Geospatial/CirgisLariacIndex2018</A></SPAN><SPAN style="border: 0px; font-weight: inherit; font-size: 14px;">"</SPAN></SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> homelandSecurity </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">new</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="border: 0px; font-weight: inherit; font-size: 14px;">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN style="color: #000000;">urlDyn</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">{</SPAN><SPAN style="color: #000000;"> id</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">"index_filenames"</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> opacity</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit; font-size: 14px;">0.7</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> visible</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">true</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">}</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> homelandSecurity</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit; font-size: 14px;">setVisibleLayers</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">[1,</SPAN><SPAN style="border: 0px; color: #990000; font-weight: inherit; font-size: 14px;">3</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">]</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN style="color: #000000;">map</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit; font-size: 14px;">addLayer</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN style="color: #000000;">homelandSecurity</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">var</SPAN><SPAN style="color: #000000;"> optionsArray </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">[</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">]</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">var</SPAN><SPAN style="color: #000000;"> drawingOptions </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">new</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="border: 0px; font-weight: inherit; font-size: 14px;">LayerDrawingOptions</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">var</SPAN><SPAN style="color: #000000;"> labelClass </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">new</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="border: 0px; font-weight: inherit; font-size: 14px;">LabelClass</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">{</SPAN><SPAN style="color: #000000;"> labelExpression</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">'['</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">+</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">"FILENAME"</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">+</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">']'</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> labelPlacement</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">'esriServerPolygonPlacementAlwaysHorizontal'</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> symbol</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">new</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="border: 0px; font-weight: inherit; font-size: 14px;">TextSymbol</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">({ haloSize: 2, haloColor: [255,255,255] }</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">,</SPAN><SPAN style="color: #000000;"> minScale</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">:</SPAN><SPAN style="color: #000000;"> 3</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit; font-size: 14px;">0000</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">}</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> drawingOptions</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN style="color: #000000;">labelingInfo </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">[</SPAN><SPAN style="color: #000000;">labelClass</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">]</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> drawingOptions</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN style="color: #000000;">showLabels </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit; font-size: 14px;">true</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> optionsArray</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">[</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit; font-size: 14px;">1,3</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">]</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit; font-size: 14px;">=</SPAN><SPAN style="color: #000000;"> drawingOptions</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">;</SPAN><SPAN style="color: #000000;"> </SPAN><SPAN style="color: #000000;">map</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit; font-size: 14px;">getLayer</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit; font-size: 14px;">(</SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit; font-size: 14px;">"</SPAN>
Do both layers in the map service have the same field name "FILENAME"?
Yes
