There is some chance your data may have previously had COGO attribute fields. COGO is mostly used with parcel or survey data and records directions and lengths into the attribute table. If COGO attributes are found, ArcMap automatically splits line segments where they change directions to make sure each feature is completely straight or curved (known as "two-point lines"). If you still have the old data, maybe you can compare it to the fields in the new data. If you find that some fields are no longer present, COGO is probably the cause of the behavior and you will need to add them again to make the lines split automatically. http://help.arcgis.com/en/arcgisdesktop/10.0/help/#/An_overview_of_COGO/001t000000mr000000/http://help.arcgis.com/en/arcgisdesktop/10.0/help/#/About_COGO_and_feature_templates/001t000000n0000000/COGO is the only built-in functionality that I can think of that would automatically split lines, although there could be add-ins or scripts out there that will do this without the added maintenance of the COGO fields. You could also use the Split Line At Vertices or Split Line At Point geoprocessing tools after you create the feature.
