GPS Program Port: COM7 GPS Hardware Port: COM2 Baud Rate: 4800 Access: Manage GPS Automatically NOT CHECKED (probably really doesn't matter) Enable Assisted GPS is checked
NMEA Output Settings Output Interval: 1s Receiver Port: Primary: Port 1 Secondary None Baud Rate: 4800 Data Bits: 8 Stop Bits: 1 Parity: None General X GGA X GLL X GSA X GSV X RMC X VTG X ZDA
Hi Douga quick question about GPS Controller. In the NMEA Output Settings page, what did u use for the Primary Receiver Port setting? Even though the GPS is on COM2, the only two options are None & Port 1.Also, I'm assuming the baud rate should be 9600.Do u have it running in the background when using AGM?Thanks again
