{ "displayFieldName": "vdate", "fieldAliases": { "vdate": "vdate" }, "fields": [{ "name": "vdate", "type": "esriFieldTypeString", "alias": "vdate", "length": 25 }], "features": [{ "attributes": { "vdate": " 2012\/04\/26-00Z" } }, { "attributes": { "vdate": " 2012\/04\/26-00Z" } }, { "attributes": { "vdate": " 2012\/04\/26-00Z" } } <snip>
<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/tundra/tundra.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); var map; function init() { var ext = new esri.geometry.Extent({"xmin":-11077893,"ymin":4210843,"xmax":-7969046,"ymax":5570810,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{ extent: ext, wrapAround180: true }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var imgParams = new esri.layers.ImageParameters(); var layerDefs = []; layerDefs[1] = "vdate like '%2012/04/26%'"; imgParams.layerDefinitions = layerDefs; imgParams.layerIds = [1]; imgParams.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW; imgParams.transparent = true; var dyn = new esri.layers.ArcGISDynamicMapServiceLayer("http://www.ncddc.noaa.gov/arcgis/rest/services/Models/NWS_AirTempForecasts/MapServer", { "imageParameters": imgParams }); map.addLayer(dyn); dojo.connect(map, "onLoad", function() { dojo.connect(dijit.byId("map"), "resize", map, map.resize); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
