Whenever I try to share a scene layer in Pro by selecting 'Share as Web Layer', it fails during the caching process. When I try to open the layer in AGOL, I get the error 'Scene Service missing root node'. Could any setting in Pro be causing this?
Can you clarify the following:
1) Which version of Pro are you using?
2) What type of data are you publishing? 3D Points, Multipatch?
3) Do you have the same issue if you run the Create Scene Layer Package tool and then add the package to AGOL either manually or using the Share Package tool?
thanks,
Andrew
