I would suggest that this is a bug, as both ways should work.
So what is a Zone Conflict? All zones are covered so I don't understand what the problem is.
This is definitely some odd behavior. I can't reproduce this scenario at the moment but I have a few ideas you might try.1. Try recreating your Friday routing folder. Move any existing orders to the Orders Inbox, delete the folder, and then recreate. >>> Tried a few times, still does not work2. If your zones always apply to the same vehicles, you might try assigning zones to your vehicle templates rather than to individual vehicles within routing folders. If you assign some zone to a vehicle this way, it will apply to the vehicle in each new routing folder you create and you won't have to manually do this for each routing folder. See attached image. >>> The scenario i have is that the customer has a few delivery zones. The vehicles does not have a fix zone as it depends on the order size and driver experience on a particular zone. 3. Also, note that you can't add/remove zones if your vehicles already have some orders assigned to them. >>> Yup .
