ArcGIS Server map services limit the number of records that can be returned by a query to 1,000 by default. Keep this value or lower it for best performance with queries. You can change the number of allowable result records by editing the MaxRecordCount property in the map service configuration file.
It looks like the spatial reference of the point feature layer may be incorrect in the JS example - are you able to verify it?There is a section in that sample (around line 123 script esri.ux.layers.ClusterLayer-debug.js) which handles projections: //this function may not be needed exactly as is below. somehow, the attributes need to be mapped to the points. setFeatures: function(features) { this._features = []; var wkid = features[0].geometry.spatialReference.wkid; if (wkid != 102113) { if (wkid == 4326 || wkid == 4269 || wkid == 4267) { dojo.forEach(features, function(feature) { point = esri.geometry.geographicToWebMercator(feature.geometry); point.attributes = feature.attributes; this._features.push(point); }, this); } else { throw 'Input Spatial Reference Must Be in Either WKID: 102110 or WKID: 4326'; return; } Perhaps try putting a breakpoint on this section and step through the code. Are you able to post a link to your site?Steve
