Hi all
How can I calculate the difference between today and a date field in ArcMap in days.
I want to select all the records that were created during the last 90 days.
Regards
The answer is very simple:
MY_FIELD_DATE < CURRENT_DATE - 90
https://community.esri.com/message/442826?et=watches.email.thread#442826
You will access the system date in your calculation and use the DateDiff function. The syntax will depend on the underlying data source, Oracle, SQL Server, etc.. Example: DATEDIFF(day, date_col ,SYSDATETIME()) < 90.
I found the answer in this post by Vince Angelo
ArcSDE supports five different RDBMSes that use SQL, all of which have different syntaxfor referring to dates and date functions. Even using just Microsoft SQL-Server, thereare multiple possible flavors (2005, 2008, 2008R2). Dates can also be difficult due tovariability of precision -- does a time reference to a day without hour imply midnightor noon, and in what timezone?What you're looking for probably involves the SYSDATETIME() function and some variantof DATEADD or DATEDIFF --where date_col > DATEADD(day,-7,SYSDATETIME())or where DATEDIFF(day,date_col,SYSDATETIME()) < 7but that depends on the exact types involved. This documentation page is probably agood starting point, but you'll likely need to experiment, since different variants of thesame expression are likely to give different performance, depending on how the indexinteracts with the expression.- V
or
- V
ArcGIS Help on SQL Query (10.2, 10.2.1, and 10.2.2)
I updated the invalid link in the original post so it goes to the intended page:
Date and Time Data Types and Functions (Transact-SQL)
