Is it possible to perform qeury task using geometries...? Wanna get results using square area or circle area on map..?
RAJ,
You were not far from the answer you just were not doing anything with the drawn geometry.
require([ "esri/Map", "esri/views/MapView", "esri/widgets/Home", "esri/widgets/Legend", "esri/widgets/Search", "esri/layers/GraphicsLayer", "esri/Graphic", "esri/widgets/Sketch/SketchViewModel", "esri/tasks/QueryTask", "esri/tasks/support/Query", "dojo/_base/array", "dojo/dom", "dojo/on", "dgrid/OnDemandGrid", "dgrid/extensions/ColumnHider", "dojo/store/Memory", "dstore/legacy/StoreAdapter", "dgrid/Selection", "dojo/_base/declare", "dojo/dom-class", "dojo/domReady!" ], function( Map, MapView, Home, Legend, Search, GraphicsLayer, Graphic, SketchViewModel, QueryTask, Query, arrayUtils, dom, on, OnDemandGrid, ColumnHider, Memory, StoreAdapter, Selection, declare, domClass ) { let map, view, grid, editGraphic; const tempGraphicsLayer = new GraphicsLayer(); let RUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Prominent_Peaks_US/FeatureServer/0"; let FUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/2015_06_26_active_fires_USA_contiguous_and_Hawaii_24h/FeatureServer/0"; let gridFields = ["__OBJECTID", "RANK", "MTN_PEAK", "STATE", "ELEV_ft", "ELEV_m", "PROMINENCE_ft", "PROMINENCE_m" ]; // create a new datastore for the on demandgrid // will be used to display attributes of selected features let dataStore = new StoreAdapter({ objectStore: new Memory({ idProperty: "__OBJECTID" }) }); const gridDis = document.getElementById("gridDisplay"); // Define the popup content for each result const popupTemplate = { // autocasts as new PopupTemplate() title: "{MTN_PEAK}, {STATE}", fieldInfos: [{ fieldName: "ELEV_ft", label: "Elevation (feet)", format: { places: 0, digitSeperator: true } }, { fieldName: "ELEV_m", label: "Elevation (meters)", format: { places: 0, digitSeperator: true } }, { fieldName: "PROMINENCE_ft", label: "Prominence (feet)", format: { places: 0, digitSeperator: true } }, { fieldName: "PROMINENCE_m", label: "Prominence (meters)", format: { places: 0, digitSeperator: true } }, { fieldName: "ISOLATION_mi", label: "Isolation (miles)", format: { places: 0, digitSeperator: true } }, { fieldName: "ISOLATION_km", label: "Isolation (km)", format: { places: 0, digitSeperator: true } }], content: "<b><a href='https://en.wikipedia.org/wiki/Topographic_prominence'>Prominence:</a>" + "</b> {PROMINENCE_ft} ft ({PROMINENCE_m} m)" + "<br><b>Prominence Rank:</b> {RANK}" + "<br><b>Elevation:</b> {ELEV_ft} ft ({ELEV_m} m)" + "<br><b><a href='https://en.wikipedia.org/wiki/Topographic_isolation'>Isolation:</a>" + "</b> {ISOLATION_mi} mi ({ISOLATION_km} km)" }; // Define the popup content for each result const popupTemplate2 = { // autocasts as new PopupTemplate() title: "{TRACK}", fieldInfos: [{ fieldName: "TRACK", label: "Track" }, { fieldName: "BRIGHT_T31", label: "Brightness", format: { places: 0, digitSeperator: true } }, { fieldName: "CONFIDENCE", label: "Confidence" }, { fieldName: "SCAN", label: "Scan", format: { places: 0, digitSeperator: true } }], content: "Brightness: {BRIGHT_T31}" + "<br><b>Prominence Rank:</b> {RANK}" + "<br><b>Confidence:</b> {CONFIDENCE}" + "<br><b>Scan: {SCAN}" }; let resultsLayer = new GraphicsLayer(); let resultsLayer2 = new GraphicsLayer(); let qTask = new QueryTask({ url: RUrl }); let qTask2 = new QueryTask({ url: FUrl }); let params = new Query({ returnGeometry: true }); map = new Map({ basemap: "streets", layers: [resultsLayer, resultsLayer2, tempGraphicsLayer] }); view = new MapView({ map: map, container: "viewDiv", zoom: 3, popup: { dockEnabled: true, dockOptions: { position: "top-right", breakpoint: false } } }); function createGrid(fields) { var columns = fields.filter(function(field, i) { if (gridFields.indexOf(field.name) !== -1) { return field; } }).map(function(field) { if (field.name === "__OBJECTID") { return { field: field.name, label: field.name, sortable: true, hidden: true }; } else { return { field: field.name, label: field.alias, sortable: true }; } }); // create a new onDemandGrid with its selection and columnhider // extensions. Set the columns of the grid to display attributes // the hurricanes cvslayer grid = new(declare([OnDemandGrid, Selection, ColumnHider]))({ columns: columns }, "grid"); // add a row-click listener on the grid. This will be used // to highlight the corresponding feature on the view grid.on("dgrid-select", selectFeatureFromGrid); } function selectFeatureFromGrid(event) { } view.when(function() { view.ui.add("optionsDiv", "bottom-right"); on(dom.byId("doBtn"), "click", doQuery); on(dom.byId("clrBtn"), "click", doClear); //Query to get unique vals let opt_ = document.createElement('option'); opt_.value = ""; opt_.innerHTML = "select State"; let opt__ = document.createElement('option'); opt__.value = ""; opt__.innerHTML = "select Peak"; statedd.appendChild(opt_); peakdd.appendChild(opt__); let qUVState = new Query({ returnGeometry: false, where: '1=1', returnDistinctValues: true, outFields: ['STATE'], orderByFields: ['STATE ASC'] }); qTask.execute(qUVState).then(function(results) { results.features.map(function(feat) { let opt = document.createElement('option'); opt.value = feat.attributes.STATE; opt.innerHTML = feat.attributes.STATE; statedd.appendChild(opt); }); }); let qUVPeak = new Query({ returnGeometry: false, where: '1=1', returnDistinctValues: true, outFields: ['MTN_PEAK'], orderByFields: ['MTN_PEAK ASC'] }); qTask.execute(qUVPeak).then(function(results) { results.features.map(function(feat) { let opt2 = document.createElement('option'); opt2.value = feat.attributes.MTN_PEAK; opt2.innerHTML = feat.attributes.MTN_PEAK; peakdd.appendChild(opt2); }); }); }); const attributeName = dom.byId("attSelect"); const expressionSign = dom.byId("signSelect"); const value = dom.byId("valSelect"); const wlayer = dom.byId("lyrSelect"); const statedd = dom.byId("stateSelect"); const peakdd = dom.byId("peakSelect"); function doClear() { if (grid) { dataStore.objectStore.data = {}; grid.set("collection", dataStore); } resultsLayer2.removeAll(); gridDis.style.display = 'none'; domClass.remove("viewDiv", 'withGrid'); } function doQuery() { doClear(); // Clear the results from a previous query resultsLayer.removeAll(); resultsLayer2.removeAll(); let whereC = []; if(statedd.value !== ''){ whereC.push("STATE = '" + statedd.value + "'"); } if (peakdd.value !== ''){ whereC.push("MTN_PEAK = '" + peakdd.value + "'"); } whereC.push(attributeName.value + expressionSign.value + value.value); params.where = whereC.join(' AND '); if (wlayer.value === 'peaks') { if(tempGraphicsLayer.graphics.length >0){ params.geometry = tempGraphicsLayer.graphics.getItemAt(0).geometry; } params.outFields = ["RANK", "MTN_PEAK", "STATE", "ELEV_ft", "ELEV_m", "PROMINENCE_ft", "PROMINENCE_m" ]; gridFields = ["__OBJECTID", "RANK", "MTN_PEAK", "STATE", "ELEV_ft", "ELEV_m", "PROMINENCE_ft", "PROMINENCE_m" ]; qTask.execute(params) .then(getResults) .catch(promiseRejected); } else if (wlayer.value === 'fires') { params.outFields = ["BRIGHTNESS", "SCAN", "TRACK", "ACQ_DATE", "ACQ_TIME", "SATELLITE", "CONFIDENCE", "VERSION" ]; gridFields = ["__OBJECTID", "BRIGHTNESS", "SCAN", "TRACK", "ACQ_DATE", "ACQ_TIME", "SATELLITE", "CONFIDENCE", "VERSION" ]; params.where = 'BRIGHTNESS > 320'; qTask2.execute(params) .then(getResults) .catch(promiseRejected); } } function getResults(response) { let graphics = response.features; if (graphics.length > 0) { gridDis.style.display = 'block'; domClass.add("viewDiv", 'withGrid'); document.getElementById("featureCount").innerHTML = "<b>Showing attributes for " + graphics.length.toString() + " features </b>" } else { gridDis.style.display = 'none'; } createGrid(response.fields); // get the attributes to display in the grid var data = graphics.map(function(feature, i) { return Object.keys(feature.attributes) .filter(function(key) { // get fields that exist in the grid return (gridFields.indexOf(key) !== -1); }) // need to create key value pairs from the feature // attributes so that info can be displayed in the grid .reduce((obj, key) => { obj[key] = feature.attributes[key]; return obj; }, {}); }); // set the datastore for the grid using the // attributes we got for the query results dataStore.objectStore.data = data; grid.set("collection", dataStore); var RResults = arrayUtils.map(response.features, function( feature) { feature.symbol = { type: "simple-marker", color: "red", size: 5, outline: { color: "black" } }; if (wlayer.value === 'peaks') { feature.popupTemplate = popupTemplate; } else if (wlayer.value === 'fires') { feature.popupTemplate = popupTemplate2; } return feature; }); if (wlayer.value === 'peaks') { resultsLayer.addMany(RResults); } else if (wlayer.value === 'fires') { resultsLayer2.addMany(RResults); } view.goTo(RResults); } function promiseRejected(error) { console.error("Promise rejected: ", error.message); } var homeBtn = new Home({ view: view }, "homeDiv"); var legend = new Legend({ view: view, layerInfos: [{ url: RUrl }] }); legend.startup(); view.ui.add(legend, "bottom-left"); var searchWidget = new Search({ view: view }); view.ui.add(searchWidget, { position: "top-right" }); view.when(function() { // create a new sketch view model const sketchViewModel = new SketchViewModel({ view: view, layer: tempGraphicsLayer, pointSymbol: { type: "simple-marker", // autocasts as new SimpleMarkerSymbol() style: "square", color: "#8A2BE2", size: "16px", outline: { // autocasts as new SimpleLineSymbol() color: [255, 255, 255], width: 3 } }, polylineSymbol: { type: "simple-line", // autocasts as new SimpleLineSymbol() color: "#8A2BE2", width: "4", style: "dash" }, polygonSymbol: { type: "simple-fill", // autocasts as new SimpleFillSymbol() color: "rgba(138,43,226, 0.8)", style: "solid", outline: { color: "white", width: 1 } } }); setUpClickHandler(); // Listen to create-complete event to add a newly created graphic to view sketchViewModel.on("create-complete", addGraphic); // Listen the sketchViewModel's update-complete and update-cancel events sketchViewModel.on("update-complete", updateGraphic); sketchViewModel.on("update-cancel", updateGraphic); //************************************************************* // called when sketchViewModel's create-complete event is fired. //************************************************************* function addGraphic(event) { // Create a new graphic and set its geometry to // `create-complete` event geometry. const graphic = new Graphic({ geometry: event.geometry, symbol: sketchViewModel.graphic.symbol }); tempGraphicsLayer.add(graphic); } //*************************************************************** // called when sketchViewModel's update-complete or update-cancel // events are fired. //************************************************************* function updateGraphic(event) { // event.graphic is the graphic that user clicked on and its geometry // has not been changed. Update its geometry and add it to the layer event.graphic.geometry = event.geometry; tempGraphicsLayer.add(event.graphic); // set the editGraphic to null update is complete or cancelled. editGraphic = null; } // ************************************************************************************ // set up logic to handle geometry update and reflect the update on "tempGraphicsLayer" // ************************************************************************************ function setUpClickHandler() { view.on("click", function(event) { view.hitTest(event).then(function(response) { var results = response.results; // Found a valid graphic if (results.length && results[results.length - 1] .graphic) { // Check if we're already editing a graphic if (!editGraphic) { // Save a reference to the graphic we intend to update editGraphic = results[results.length - 1].graphic; // Remove the graphic from the GraphicsLayer // Sketch will handle displaying the graphic while being updated tempGraphicsLayer.remove(editGraphic); sketchViewModel.update(editGraphic); } } }); }); } //************************************* // activate the sketch to create a point //************************************* var drawPointButton = document.getElementById("pointButton"); drawPointButton.onclick = function() { // set the sketch to create a point geometry sketchViewModel.create("point"); setActiveButton(this); }; //**************************************** // activate the sketch to create a polyline //**************************************** var drawLineButton = document.getElementById("polylineButton"); drawLineButton.onclick = function() { // set the sketch to create a polyline geometry sketchViewModel.create("polyline"); setActiveButton(this); }; //*************************************** // activate the sketch to create a polygon //*************************************** var drawPolygonButton = document.getElementById("polygonButton"); drawPolygonButton.onclick = function() { // set the sketch to create a polygon geometry sketchViewModel.create("polygon"); setActiveButton(this); }; //*************************************** // activate the sketch to create a rectangle //*************************************** var drawRectangleButton = document.getElementById( "rectangleButton"); drawRectangleButton.onclick = function() { // set the sketch to create a polygon geometry sketchViewModel.create("rectangle"); setActiveButton(this); }; //*************************************** // activate the sketch to create a circle //*************************************** var drawCircleButton = document.getElementById("circleButton"); drawCircleButton.onclick = function() { // set the sketch to create a polygon geometry sketchViewModel.create("circle"); setActiveButton(this); }; //************** // reset button //************** document.getElementById("resetBtn").onclick = function() { sketchViewModel.reset(); tempGraphicsLayer.removeAll(); setActiveButton(); }; function setActiveButton(selectedButton) { // focus the view to activate keyboard shortcuts for sketching view.focus(); var elements = document.getElementsByClassName("active"); for (var i = 0; i < elements.length; i++) { elements<I>.classList.remove("active"); } if (selectedButton) { selectedButton.classList.add("active"); } } }); });<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN></I>
Sure here is a sample that queries based on the view extent.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=featurelayerview-query
Above sample also helpful. But am looking for user defined geometry query task (spatial filter).. So he can draw a geometry(extent, circle, freehand polygon ) along with query task.. So the result combined both ones..
For something like that you would have to combine this sample with what you have:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=sketch-geometries
Thank you for the link Robert.. I'll try to combine it along with the query task..
Hi Robert, I tried to add this spatial filter into existing query but cant able to use it with queries. can you help me out..only able to use as a sketch tool to draw these geometries..
Am sharing fiddle. Please check it once.
QueryTask - 4.8\n \n \n\n\n\n \n \n Prominent Peaks in the U.S.\n \n US Fires\n US Peaks\n…
Its perfectly working. Let me check again how it works. I tried to do it with using
spatialRelationship: "esriSpatialRelIntersects", outFields: ["*"]
but it was difficult for me to use both(queries and spatial filter) with each other..
Appreciate your help Robert. Thanks a lot..
