My points are lat/long based and being plotted manually via a function call (addPointToMap(lon, lat)). The function created an esri.geometry.Point using the lat/long information, creates a esi.symbol.SimpleMarkerSymbol, and then adds a new graphic to the map using the point and marker. Like this:[INDENT]var point = new esri.geometry.Point(lon, lat, map.spatialReference);[/INDENT][INDENT]var marker = new esri.symbol.SimpleMarkerSymbol();[/INDENT][INDENT]marker.setColor(new dojo.Color([255, 0, 0, 0.5]));[/INDENT] [INDENT]map.graphics.add(new esri.Graphic(point,marker))[/INDENT]
I think you'll need to add your points to a featureLayer based on a featureCollection, then set the time definition for the layer. After that, the layer will be time-aware and you can use the time-slider.If that doesn't work, try adding the points to a new layer inside ArcMap, set the time definition there, and publish the layer to ArcGIS Server or ArcGIS Online.Steve
function init() { var zoomSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([0, 0, 255]), 2), new dojo.Color([255, 255, 0, 0.5])); esri.config.defaults.map.zoomSymbol = zoomSymbol.toJson(); var mappingURL = (mapURL != null) ? mapURL : ''; if (mappingURL != '') { map = new esri.Map("map"); dojo.connect(map, "onLoad", initFunc); var baseLayer = new esri.layers.ArcGISTiledMapServiceLayer(mappingURL); var layerDefinition = { "geometryType": "esriGeometryPolygon", "fields": [{ "name": "BUFF_DIST", "type": "esriFieldTypeInteger", "alias": "Buffer Distance" }] } var featureCollection = { layerDefinition: layerDefinition, featureSet: null }; featureLayer = new esri.layers.FeatureLayer(featureCollection, { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT }); var defn = new esri.TimeExtent(); defn.startTime = new Date("2/3/2013 UTC") defn.endTime = new Date("2/4/2013 UTC"); featureLayer.setTimeDefinition(defn); map.addLayer(baseLayer); map.addLayer(featureLayer); dojo.connect(baseLayer, "onError", function (err) { alert("ArcGIS Mapping Not Available (" + err.code + " : " + err.message + (err.details ? "\n" + err.details.join("\n - ") : "") + ")"); $('#contactMapDiv').width('0%'); }); } else { $('#contactMapDiv').width('0%'); } } function initSlider() { var timeSlider = new esri.dijit.TimeSlider({ style: "width: 100%;" }, dojo.byId("timeSliderDiv")); map.setTimeSlider(timeSlider); var timeExtent = new esri.TimeExtent(); timeExtent.startTime = new Date("2/3/2013 UTC"); timeExtent.endTime = new Date("2/4/2013 UTC"); timeSlider.setThumbCount(2); timeSlider.createTimeStopsByTimeInterval(timeExtent, 2, 'esriTimeUnitsHours'); timeSlider.setThumbIndexes([0, 1]); timeSlider.setThumbMovingRate(2000); timeSlider.startup(); //add labels for every other time stop var labels = dojo.map(timeSlider.timeStops, function (timeStop, i) { if (i % 2 === 0) { return timeStop.getUTCFullYear(); } else { return ""; } }); timeSlider.setLabels(labels); dojo.connect(timeSlider, "onTimeExtentChange", function (timeExtent) { var startValString = timeExtent.startTime.getUTCFullYear(); var endValString = timeExtent.endTime.getUTCFullYear(); dojo.byId("daterange").innerHTML = "<i>" + startValString + " and " + endValString + "<\/i>"; }); } function initFunc(map) { initSlider(); } function addLineToMap(pt1, pt2) { //create points array var points = [pt1, pt2]; //create polyline var polyline = new esri.geometry.Polyline(map.spatialReference); polyline.addPath(points); //create graphic var line = new esri.Graphic(polyline, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 255, 255]), 1)); //add graphic to map featureLayer.add(line); } function addPointToMap(lon, lat) { var point = new esri.geometry.Point(lon, lat, map.spatialReference); if (point1 == null) { point1 = new esri.geometry.Point(lon, lat, map.spatialReference); } else { if (point2 != null) { point1 = point2; } point2 = new esri.geometry.Point(lon, lat, map.spatialReference); addLineToMap(point1, point2); } var marker = new esri.symbol.SimpleMarkerSymbol(); marker.setColor(new dojo.Color([255, 0, 0, 0.5])); featureLayer.add(new esri.Graphic( point, marker )); // map.graphics.add( // new esri.Graphic( // point, // marker // ) // ) //var wmpoint = esri.geometry.geographicToWebMercator(point); map.centerAndZoom(point,7); } dojo.addOnLoad(init); function PlotMap(rowID) { point1 = null; point2 = null; featureLayer.clear(); $.ajaxSetup({ cache: false }); $.getJSON(getMapPointDataURL, { id: rowID }, function (mapPointData) { $.each(mapPointData, function (index, itemData) { if ((itemData.Text != "") && (itemData.Value != "")) { var lathour = itemData.Text.substring(0, 2); var latminute = itemData.Text.substring(2, 4); var lat = parseFloat(lathour) + parseFloat((latminute) / 60); if (itemData.Text.substring(4) == "S") { lat = "-" + lat; } var longhour = itemData.Value.substring(0, 3); var longminute = itemData.Value.substring(3, 5); var long = parseFloat(longhour) + parseFloat((longminute) / 60); if (itemData.Value.substring(5) == "W") { long = "-" + long; } // alert(long + ', ' + lat); addPointToMap(parseFloat(long), parseFloat(lat)); } }); $.ajaxSetup({ cache: true }); }); }
