I'm working with arcgis web app right now.
in that web app i want to visualize data from KML url, but unfortunately it failed.
the steps that i did is
1. I successfully created web map in arcgis online and add KML web map layer and save it as gsmap.
2. Then i go to the content and select gsmap and create a web app -> using template and created a new web app, but i cannot see the layer from KML
i did quick investigation about the problem and found this problem, width of image source is 0 px.
if i remove the width or change the value upper than 0 it worked
Here is the kml file
<SPAN class="prolog token"><?xml version="1.0" encoding="UTF-8"?></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>kml</SPAN> <SPAN class="attr-name token">xmlns</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.opengis.net%2Fkml%2F2.2" target="_blank">http://www.opengis.net/kml/2.2</A><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>gx</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.google.com%2Fkml%2Fext%2F2.2" target="_blank">http://www.google.com/kml/ext/2.2</A><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>kml</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.opengis.net%2Fkml%2F2.2" target="_blank">http://www.opengis.net/kml/2.2</A><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>atom</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.w3.org%2F2005%2FAtom" target="_blank">http://www.w3.org/2005/Atom</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Document</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>map_rain.kml<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Folder</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>GSMaP Passage Data<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>map_rain<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Rain<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<ListStyle>
<listItemType>checkHideChildren</listItemType>
<bgColor>00ffffff</bgColor>
<maxSnippetLines>2</maxSnippetLines>
</ListStyle>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>GroundOverlay</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Icon</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>href</SPAN><SPAN class="punctuation token">></SPAN></SPAN>map_rain.png<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>href</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Icon</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>altitude</SPAN><SPAN class="punctuation token">></SPAN></SPAN>100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>altitude</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>altitudeMode</SPAN><SPAN class="punctuation token">></SPAN></SPAN>absolute<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>altitudeMode</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LatLonBox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>north</SPAN><SPAN class="punctuation token">></SPAN></SPAN>60<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>north</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>south</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-60<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>south</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>east</SPAN><SPAN class="punctuation token">></SPAN></SPAN>200<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>east</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>west</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-160<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>west</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LatLonBox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>GroundOverlay</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Folder</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Document</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>kml</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
and this is the image
Really appreciate of your help.
