do you mean like int(str) or float(str)... I never liked Val("1") when you wanted a float or Val("1.0") when you wanted an integer. The explicit casting of int(str) and float(str) are nice and for the bold.... complex("1") => (1+0j) even does casting into the complex plane
This is of no help, but I'd like to mention that MapBasic/MapInfo has had the function Val(str), from the start. And it has been of great use to me. Today I miss it in ArcGIS. Incidently, not even FME or Excel seem to have a straightforward transformer or module to do this. Strange indeed.
from Phil's 2nd post... where a solution works 95% of the time.. perhaps find a solution for it and then determine whether the remaining 5% has unique characteristics that the first 95% doesn't share... Often a two stage solution is faster and more elegant than a one-pass run. It would be interesting to see this type of dataset broken down on those lines. I am sure that people dealing with geocoding all the time, can come up with examples where failure of the one-step solution occurs all the time.
def get_num_from_string(string): '''This function retrieves numbers from a string and converts them to integers''' # Create empty string to store numbers as a string num = '' # Loop through characters in the string for i in string: # If one of the characters is a number, add it to the empty string if i in '1234567890': num+=i # Convert the string of numbers to an integer integer = int(num) return integer
>>> text = 'Value = -12.214' >>> num = get_num_from_string(string) >>> num 12214
get_num_from_string(!ADDRESS!)
Thank you, Xander. I am totally new to Python and am finding that it is not as intuitive as I had hoped. But, I will see if I can apply what you sent to ArcMap. Maybe I will get ambitious and take one of ESRI's online courses on Python. Best wishes.Phil
import re text = 'There is some 234198372 data in here' print re.findall('\\d+', text)
['234198372']
>>> str = "h3110 23 cat 444.4 rabbit 11 2 dog" >>> [int(s) for s in str.split() if s.isdigit()] [23, 11, 2]
This will not recognise floats, negative integers, or integers in hexadecimal format.
lstRoads = ['US Hwy 1', 'State Hwy 33 W','State Hwy 29 Bus', 'some 1 other string text with a number','yet another test with a 6 number'] for r in lstRoads: lstr = r.split(' ') for i in range(len(lstr)-1,-1,-1): if lstr.isdigit(): print " - part {0} - in string '{1}' is '{2}' and this is numeric {3}".format(i,r,lstr,float(lstr)) break
