Hello,From your post it seems as though you have ArcPad functioning correctly and can successfully create and manipulate shapefiles with ArcPad. Your main question is how to get shapefiles into AutoCAD, is this correct?If this is the case then it's probably not so much an ArcPad question but rather a general ArcGIS Desktop question. Do you have access to ArcGIS Desktop? You'll need to use ArcGIS Desktop to export those shapefiles out to a format which AutoCAD can read. ArcPad does not provide this type of functionality.Here's a few web help articles which discuss the workflows that can be used to export shapefiles or feature classes to cad drawings:Exporting data to CAD drawings http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001000000076000000.htmExport To CAD (Geoprocessing Tool) http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00120000001n000000You have the ability with this tool to export using default settings or to use an existing seed file to alter the way the cad drawing looks after running the GP tool.If you run into any issues utilizing these tools or have additional questions about their functionality, I would suggest posting to the general ArcGIS Desktop usage forum:http://forums.arcgis.com/forums/5-ArcGIS-Desktop-GeneralIf I've misunderstood and you're having trouble actually creating and working with the shapefiles in ArcPad, please respond here with some additional info.Thanks!
Can I ask that you expand on the following comment you made in your initial post:"The data collection software we had written for ArcPad seems to finally be working after having it "tweaked"."What sort of collection software have you written and how does it interact with ArcPad? I initially was under the impression that you were successfully working with shapefiles in ArcPad, but I see that this is not the case. Are you simply trying to create new shapefiles and add data to them in the field or have you written some sort of application the somehow sits on top of ArcPad?Are you receiving an error when you try to add the shapefiles to ArcPad or do you not know how to add them in the first place?From the main toolbar in ArcPad, there is a button with a yellow diamond with a green and white plus sign. This button allows you to navigate to and add shapefiles to your document. You also have the ability to create brand new shapefiles in ArcPad, via File (ArcPad icon in upper left) > New > Shapefile.You do not necessarily need ArcGIS Desktop to work with ArcPad. ArcPad can function by itself as a stand-alone program. If you did have ArcGIS Desktop, you have greater functionality with ArcPad by being able to "check out and check in" data.ArcPad Studio is a separate application for customizing ArcPad. You can customize the way that attribute forms of shapefiles look and add additional functionality via scripting to ArcPad. It is not required that you use ArcPad Studio. ArcPad out-of-the-box will allow you to create new shapefiles or consume existing shapefiles.ArcGIS for Windows Mobile is a separate mobile application similar to ArcPad (does not have any interaction at all with ArcPad) and DOES require that you have ArcGIS Desktop. You cannot create data or projects for ArcGIS for Windows Mobile without ArcGIS Desktop.For you, ArcGIS Desktop would come into play if your end result is utilizing the shapefiles used in ArcPad within an AutoCAD application. ArcGIS Desktop has geoprocessing tools which will convert the shapefiles into a dwg or other format readable by AutoCAD. Now, I do believe that there are also import tools in AutoCAD which will allow you to import shapefiles, but I personally don't have much experience with that. If you're interested in learning how to import shapefiles into AutoCAD without using ArcGIS Desktop, I would post that question on the AutoCAD forums instead.The ArcPad Web Help and the additional links below will help to familiarize you with the capabilities of ArcPad.Field GIS: Collecting and Editing Data Using ArcPad 10 (free training course)http://training.esri.com/gateway/ind...&courseid=2103ArcPad Videoshttp://resources.arcgis.com/gallery/video/arcpadDoes this help?If you are running into particular issues with specific functionality in ArcPad and are current on your ArcPad maintenance, I would suggest logging a new support incident with Esri Support Services. We'd be happy to help you with specific questions you had regarding utilizing ArcPad.
Hi CAD-Coordinator,I have the same gripe with autocad.. its not actualy the scale.. it is because there is no defined block template to the mapimport(points) function where as if you import survey data in X,Y,Z,point Code from a CSV file it has a great block template.the esiest way I have found so far which is hacked up is setting a theme from the map workspace or when iporting you can select the block such as this. http://www.youtube.com/watch?v=_rDCE1JhQFACheers Graham
